Loquah
Ebay.............
I've just checked their's plenty of 5998 and they cost plenty of money as well.
Do you really need the 5998 for the CRACK?Does this tube improved the sound quality of the CRACK that much?
I changed the OUTPUT CAPS on my CRACK i paid $125 for 2 caps(See pictures).Does this cap improved the sound?Yes a little bit not like it's night and day diference IMO the improvement is not worth $125.I installed 23 stepped attenuator and IMO it only fixed the channel imbalanced and the attenuator it reduced the bass,is this attenuator upgrade worth it?maybe.
If i'am going to build another CRACK i will just install the Speedball and be done with it.The CRACK's sound with the Speedball is really really good IMO no need for anymore modifications because this amp is well put together.Sorry folks!
Just to clarify, there are many different attenuators out there. We discussed some irregularities with the one you received (pictured) prior to the installation so I don't think it's a representative example of what's possible. I didn't notice this the first time because we were so focussed on the stereo / mono question, but if you look at the picture, the attenuator is built with some Dale resistors (plain brown with printed ratings) and various other resistors. Having used a 100% Dale resistor attenuator in my S.E.X. (and based on many other accounts from other experienced builders) I can safely say that a high quality attenuator will do a lot more than just fix channel imbalances and is probably the best bang-for-buck modification after the Speedball.
I agree that capacitors are a more subtle upgrade, but with a more transparent attenuator you may find that the caps are able to exert more influence on the sound of your Crack. I built a Crack for a friend recently using the MCaps (as you've used) along with some upgraded power supply caps and a Dale stepped attenuator and the results were excellent and a noticeable improvement on the already outstanding stock sound of the Crack + Speedball.
