Merloobi
- Sep 6, 2013
Where in the world are you located?
I'm located in the North Texas (Dallas), USA
- pull out the tubes and wrap them up
- thoroughly tape down the plate to the base (something that comes off easily without residue, like painter's tape)
- if there's space, tuck the tubes snugly inside the case somewhere, adding padding and tape as necessary
- wrap the nontransformer end of the amp tightly in bubblewrap or foam packaging stuff, then tape that sucker down (wrap end over end with packaging tape to really secure it in case the painter's tape fails)
- wrap lengthwise over the transformer now with more bubblewrap or foam sheets; if you didn't fit the tubes inside the case, you might tuck them sidewise here next to the transformer then tape 'em down
- gently see if the plate wants to lift off the base. If so, you didn't secure everything tightly enough!
- put the whole thing in a box, stuff all sides and top firmly so it doesn't slide around; I'd even put an extra sheet of thick cardboard on the bottom (I actually used a flap from a broken binder/folder) in case something stupid happens
- photocopy the parts list and put it in there; if USPS screws things up and breaks something, you'll want that in there
- don't forget that power cord
- tape up the box, wrap in paper, tape up some more
The packing suggestions above are generally in accord with what Bottlehead recommends except for one important exception -- the suggestion to "tuck the tubes snugly inside the case somewhere" is exactly the wrong thing to do, because anything stuffed inside the case can press against the wires and components, and break a connection during shipping.
Did you manage to fit those in the chassis?![]()
Yeah, I am kind of amazed at the number of repeat offenders, I mean returning customers we have for Crack. We have several customers who have bought three or four Crack kits and many who have bought at least two. It seems that some build them to give as gifts and I suppose a few build them to sell. The number of kits sold has gone up tremendously in the past year. So there are bound to be some more around for sale because of the sheer number of them out there. It's interesting to go through various forum threads and find a post here and there where someone built a Crack, sold it, regretted it and bought another Crack kit.
My take has always been that you are only experiencing half the fun if you don't build your own kit. Plus, one that you built yourself always sounds better.
