It's on pre-sale now.
Cowon P1's spec isn't so different from AK240. It's battery life is about the same as AK240.
My only concern is they could have used a batter DAC and put a 1/4 headphone jack.
Classification
[COLOR=666666]MP3[/COLOR]
Display
3.7 "AMOLED Touch Display (480x800)
Storage Capacity
Built-in memory: 128GB / External Memory : microSD SDXC
[COLOR=000000][COLOR=666666]Case[/COLOR][/COLOR]
Full Metal unibody high strength
Button
POWER/HOLD, PLAY/PAUSE, VOL+, VOL-, FF, REW
CPU
[COLOR=666666]ARM Cortex A9 1.2GHz Dual-Core[/COLOR]
File Format
DXD/DSD/FLAC/WAV/AIFF/ALAC/APE/[COLOR=666666]MP3/WMA/OGG[/COLOR]
Audio codec
DXD: 352.8/384kHz ~ (1/2 Sampling)
DSD: ~ 5.64MHz (DSD64, DSD128)
FLAC, WAV, AIFF, ALAC: ~ 24bit/192kHz
(352.8/384kHz FLAC, WAV 1/2 Sampling)
MP3: MPEG 1/2/2.5 Layer 3, ~320kbps
WMA: ~320kbps, ~48kHz
APE: Fast compression (Fast), Normal (Normal), high compression (High) 16bit
OGG: ~Q10, ~44.1kHz
Lyrics
LRC, LDB, Lyrics3, ID3 Tag Lyrics (time information, yes / no)
JetEfect 7
54 preset, 10 Band Equalizer, BBE +, Chorus (8 models), Reverb (8 models)
DAC
Burr-Brown PCM1792A
SNR
120dB
THD+N
0.0006%
Stereo Crosstalk
-134dB
Output
2Vrms
[COLOR=666666]Impedance[/COLOR]
3ohm
Volume
Step 140
Clock
Clock precision TCXO (Phase Jitter 1.0ps)
[COLOR=666666][COLOR=000000]Battery[/COLOR][/COLOR]
3,000 mAh/3.7v built-in lithium-polymer battery
Play time
About 8 hours, 30 minutes
Charging time
About 4 hours (or more input conditions Micro USB DC adapter 5V/2A)
Output terminal
[COLOR=666666]Earphone jack (3.5mm) / optical output (3.5mm)[/COLOR]
Player
Various playback screen skins, analog level meters, Matrix Browser, Multi-Favorite
Connect PC Specifications
CPU: Pentium III 500MHz 이상
OS: Window 8/7/vista/XP/2000/ME: All functions supported
MAC OS 10.x / Linux v2.4 or higher: File transfer support
USB포트 : USB 2.0 high speed 권장
Size / Weight
64.5 x 116.4 x 13.4mm / 173g
