- Nov 26, 2014
Could anyone test a 200gig card? Is it working?
A lot of user tested it, it's somewhere deep in this thread
But it never worked. All files over 128gb never get played by the cowon. So i ask right now, if they fixed that?
Hi all,
Just a quick question - I am pretty ignorant of all things computery, and having finally become sick to death of iPods I'm thinking of buying one of these fancy Plenue D oojamajigs. All I want to do is play mp3's, create playlists, and listen to podcasts. Is this device simple enough for someone who types with one finger whilst wearing an expression of close concentration to understand? I'm not too interested if it'd take a qualification in computer science to use (as some of the posts in this thread seem to infer).
Thanks for your advice.
Matt
Hi,i'm new on this forum but thought this was a good place to ask a question.I have just got my Plenue D but i notice clicks when changing eq and also when you activate BBe along with the other options.Is this normal?Many thanks in advance.
Matt:
Using the PD to listen to music is very easy. There are a couple of gotchas along the way though.
Getting the microSD card set up properly takes a bit of technical effort, but it's a one-time job (well, one time each time you buy a card, which might only be once). Depending on how good a friend your technical buddy is, it'll cost you a six-pack, or maybe even a twelve-pack. It's probably not beyond the abilities of a one finger typist, but since you only do it once, probably better to pay your buddy than to risk the permanent frown lines you'll acquire if you try to muddle through on your own.
Setting up playlists is either really annoying and time-consuming, or somewhat technically complex. The difference is if you create the playlists directly on the player by selecting individual songs and adding them to the 'Favorites' lists (of which there are 10), or create them on the computer and then move them to the player. Again, you're going to enlist your buddy's help to walk you through the process a couple of times until you can repeat it on your own.
If you don't have such a friend, then I would say that you're in for a fair amount of discomfort. So, to borrow from Clint Eastwood, 'You have to ask yourself, do you feel lucky?' (Actually, the question is, Are you ready for a learning experience?)
BTW, as I type this assessment, I'm thinking of my Dad, whom I do quite a bit of Tech Support for. He also frowns quite a bit as he types, although he does use 2 fingers.
Did you update the Cowon Plenue D firmware for the latest? (1.17)
If it's got 32 gig without a card
