@Twister6 any impressions yet?
Cowon Plenue 2 - Taking it a step further.
- Thread starter Niyologist
- Oct 6, 2013
Well, I already posted a few of my initial impressions, and will probably summarize it by the weekend on a my blog (will share it here). Just have a few other reviews in my queue to finish and don't want to be distracted... I still find its sound quality to be very close to LPG, it's like LPG with a touch screen, JetEffects, balanced HO, and two slightly loose knobs
Well, I already posted a few of my initial impressions, and will probably summarize it by the weekend on a my blog (will share it here). Just have a few other reviews in my queue to finish and don't want to be distracted... I still find its sound quality to be very close to LPG, it's like LPG with a touch screen, JetEffects, balanced HO, and two slightly loose knobsBottom line, I LOVE IT!!!
Ow man. Looking forward to your review twister6, I like your write on DX200.
- Oct 6, 2013
Thanks!
Btw, did a few battery tests. Fully charged, playing mp3 in a loop at a normal listening volume with UERR and screen off. Getting about 9hrs and 20min of battery life. Will try next with high res files and more demanding headphones.
- Oct 6, 2013
Thanks!
... and high res playback (DSD64 track in a loop, with a screen off): 8hrs and 40min.
LCMusicLover
@twister6
I'm trying to play content from my iPhone to the P2, streaming or local music. Unfortunately, the P2 draws charge from the phone. The P2 drained the phone battery in less than an hour from 77% charge in my test, which pretty much makes this unusable.
I've sent a request to Cowon, and they say they'll look into it. I also posted on discussions.apple.com, but have gotten no response there yet.
Any ideas?
Anybody else?
Any ideas?
Anybody else?
- Oct 6, 2013
@twister6
Any ideas?
Anybody else?
Are you trying to use Plenue 2 as your external USB DAC to an iPhone through some camera kit, like an USB OTG connection? I guess that would be the only way, I assume. I don't know if it intended/designed to work as an external USB OTG DAC while drawing power from internal P2 battery, or maybe something is wrong with your iPhone camera kit cable, or some other setting. Too many variables... But sounds like in the setup you're describing, you are expecting P2 to use it's own power while it's drawing juice from your iPhone.
If there is no work around, I would suggest getting an adapter to connect Plenue 2 to iPhone with an extra y-splitter connection to attach external battery to keep your phone happy.
LCMusicLover
Yes, using MFi certified interconnect w/ micro USB to lightning. Connects fine, plays fine. Just have the battery-drain problem.
I just got a response from info@jetaudio.com. They said:
"I got the answer from our headquarters that P2 can be charged while it’s connected for DAC. It was designed like that because DAC feature mostly works with computer."
'Mostly' being the operative word in this case.
to which I replied:
'(a bunch of words reiterating the problem) Please add the ability to turn off charging.'
and they came back with:
'Thank you for your suggestion.
We request it to our headquarters so that they can add the feature soon.'
I don't think there's a splitter solution. It seems very unlikely that the lightning port can both output charging current to the P2 while simultaneously receiving charging current from an external battery. I'd be very reluctant to even connect such a setup -- seems like a recipe for disaster.
Does make me think of the idea of a charging case for the iPhone.
Anyway, thanks for your input. I suspect I'll be waiting/hoping for Cowon to add a feature, although I suspect it's unlikely.
Rockcoon
- Feb 23, 2015
Well, I already posted a few of my initial impressions, and will probably summarize it by the weekend on a my blog (will share it here). Just have a few other reviews in my queue to finish and don't want to be distracted... I still find its sound quality to be very close to LPG, it's like LPG with a touch screen, JetEffects, balanced HO, and two slightly loose knobs Bottom line, I LOVE IT!!!
Wow! Cowon 2 is like LPG with blackjack and volume knobs
I'm very, VERY interested.
evolutionx
Looking forward to your detailed impressions. P2 is in amazon cart waiting.......
Joseph Lin
- Nov 8, 2016
For $1,700? There are better options.
evolutionx
It was $1290 from Jet Audio. Guess they sold the last one. I am not going to pay $1700 for sure. Will pick up from Japan when I am there end of the month.
jmills8
Previously known as bmiamihk, jmills2
ITS NOT 1700.It was $1290 from Jet Audio. Guess they sold the last one. I am not going to pay $1700 for sure. Will pick up from Japan when I am there end of the month.
- Oct 6, 2013
I remember when PM2 went on sale, JetAudio pricing (both on amazon and ebay) fluctuated quite a lot, even as much as +/- $150 and more.
evolutionx
ITS NOT 1700.
Definitely not 1700. Problem is most of the sellers (jet Audio, AMP3 UK) don't ship to Singapore. Local distributor is not bringing in. Guess I will get it in Japan since it is now so close to my trip.
