try with computer and report back to see if mojo works?
Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
SilverEars
- Sep 18, 2013
I had the LCD2 which I rid of due to less mid presence after getting it to drive properly. My experience was that it doesn't get driven easily like the dynamics(hd650) with the same source. Same issue with Ether Flow C. Mid presence wasn't all thay coherent. I mean come on, it cost 1.7k. Why do I get better clarity from a $300 planar? Unacceptable. Some of these high-end prices being such a disappointing risk is rediculous.During the last year Thanksgiving sale, I have got LCD-2. With Mojo, they sound weak. Sounds like they are not playing with full potential. Is it an issue with Mojo (can't power LCD-2) or my set of LCD-2 got some issues?
Who said more performance generally scale with price?
SomeGuyDude
- Jun 24, 2012
So basically you're saying it's the headphones' fault that you didn't give them good amplification. Nice work.
SomeGuyDude
- Jun 24, 2012
The Mojo doesn't do especially well with big planars that I've found. My LCD-X sounds significantly better out of the Deckard than the Mojo.
NaiveSound
- Nov 8, 2015
I did, it's like the pc/smartphone or mojo recognize the connection to mojo as the power button lights ip, but after a little while the power button goes off with the volume buttons still on. But no music being played at any time
Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Sounds like you have a fully depleted battery.I did, it's like the pc/smartphone or mojo recognize the connection to mojo as the power button lights ip, but after a little while the power button goes off with the volume buttons still on. But no music being played at any time
Turn it off; connect the charger; make sure the light under the charger is white and does not flash; leave it to charge overnight. If it is fully depleted, it could take 12 hours to re-charge.
x RELIC x
The Deckard was exceptionally warm to me when I tried it at a meet last summer when I purchased my LCD-i4 (using my DAVE as a reference).
Yourmomm
- Jun 17, 2016
I was thinking this, too. Are you sure you're charging it properly? Flashing white light under charging cable means it's NOT charging properly...and that you need to connect it to a more powerful charger...
svfoo123
- Sep 26, 2009
I have been running the Mojo through my pc attached to my LCD 2014 Fazor and I feel that it does an exceptional job of instrument separation and powering it.
SilverEars
- Sep 18, 2013
If you read it again, that's not what it states.So basically you're saying it's the headphones' fault that you didn't give them good amplification. Nice work.
Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
I think people are confusing the sound signature of an amp with its ability to drive headphones. As long as the basic requirements are met, the same amount of power is used for any given headphone to reach any given SPL regardless of the amp. Just because you like the sound more doesn't mean it's "driving it better" or whatever.
- Feb 11, 2008
Longtime readers of this thread will already be familiar with this, but for more recent newcomers, here is something on driving Audeze headphones using Mojo:
https://www.head-fi.org/threads/cho...n-3rd-post-◄★☆.784602/page-1230#post-12631354
NaiveSound
- Nov 8, 2015
Thank you so much kind sir. I have done that, it is now fully charged. But like before, when I first turn on mojo and connect it to pc/smartphone via otg cable it stays red for a short while then it will tunnoff. Thr volume buttons always stay on. Android says there is no USB, it asks me to (charge /midi/transfer files) ect. UAPP says that it cannot detect a dac. Windows shows nothing at all.
I don't have anything that will play to mojo via optical or coax. I have a tv.... But no audio sources.
Listening at music out of my phone is just garbage, I got so burned in with mojo thst nothing else is decent.
I loved my mojo and took very very good care of it.... I wish there was something I could do. Money is very tight and I wish I could fix it somehow myself
- Apr 18, 2016
Try uninstalling UAPP and restart your phone. Do the same with the Chord drivers on your windows pc.
If there is a red light when you plug in your phone that means a handshake between Mojo and the connected device has just been established.
Drivers could sometimes mess with the handshake so it makes sense to reinstall them if things aren't working.
Jawed
- Dec 7, 2014
I found, when comparing DAVE and Hugo TT, that at higher listening levels bass would sound very slightly "phat" on TT versus DAVE at the same level, playing into HD 800 S. Turning down the volume on both, the phatness disappeared from TT.I think people are confusing the sound signature of an amp with its ability to drive headphones. As long as the basic requirements are met, the same amount of power is used for any given headphone to reach any given SPL regardless of the amp. Just because you like the sound more doesn't mean it's "driving it better" or whatever.
So, while TT theoretically has far more power and voltage swing than HD 800 S needs, it turns out that it's still possible to hear distortion at higher listening levels (not insane, about -22dB on DAVE, I don't know what colours that is on Mojo). Normally an amplifier's power is specified along with distortion, e.g. 0.1%. Distortion rises with increasing loudness and Chord's cheaper DACs with headphone output will be heard producing more distortion than expected at normal levels. DAVE, despite being more powerful, probably does have comparatively audible distortion with the trickiest, hardest to drive, headphones, even if it doesn't clip.
Before I did a proper comparison, I swore blind that TT is powerful enough for HD 800 S based on the specifications. Now I prefer to post occasional reminders that the power/distortion specifications are misleading. Mojo has about the same power/distortion ratings as Hugo TT.
My friend's Mojo sounds absolutely awesome driving HD 650s, for what it's worth. You have to spend thousands of dollars to get a worthwhile upgrade on that...
Now playing: Three's Company - Danny Boy
