Jawed
- Dec 7, 2014
For USB cables, with or without a Jitterbug (I use 2 - one on USB, one just plugged into PC), ferrite clip on cores like these:
https://www.amazon.co.uk/dp/B01E5ALVWQ
put on the USB cable will help to clean up the RF noise that causes problems. Put 4 or more on the USB cable near the Mojo - there's no way to use too many
Obviously this is for desktop use, prolly a bit awkward when you're on the go.
You should choose cores that are designed to fit tightly on your USB cable. 3mm is a common size for USB cables, but find out the size of your own cable before choosing. They're so cheap, it's an experiment everyone who uses USB should try.
Now playing: Radiohead - National Anthem
