I noticed that with certain EQ settings, lowering the volume by a certain amount via a preamp (even a digital one like reducing the volume on your player) is recommended.
Is this necessary at all with the Mojo?
Can't I just keep my player volume at maximum and control the volume with the Mojo?
I'm don't think it's any different on the Mojo. Any time you boost certain frequencies and your volume is at 0.0, you can run into clipping distortion. You should therefore lower your volume by at least the db you boost in EQ to avoid clipping.
They are certainly not immune to clipping, that would defy sound-science. The DAC will provide a highly accurate signal, if you feed it distortion/clipping, that is what's accurate. In fact, many if not most songs have harmonic distortion and sometimes clipping as part of the song. It would be quite bad if the DAC changed any of that so that it was missing.
However on the other hand, lowering the volume should have a lesser affect on resolution than other DACs due to Chords excellent digital volume implementation.
I know i should use WASAPI/ASIO if possible, but if its not what settings should i set the Mojo in Windows Settings? I do have some problems with Tidal being in exclusive mode and still it tells me to change the sound settings to 44.1 HZ 16Bit. Sometimes it works sometimes it does not.
So should i set Windows settings to 44.1 16 Bit or even 44.1 24 Bit?
From as far i know 99% of the music on Tidal is in this format. If im using foobar with other formats WASAPI works from there.
How do I get the coax connection to work? (Just wanted to try it.)
I used a cable with 1/8" termination on both ends. One end is connected to a headphone output on my laptop and the other is connected to the coax input on the Mojo. No USB cable is connected. The power light turns off when it is not connected via USB. I tried various output settings in foobar2000, but there is no audio.
The headphone out of your laptop is analogue and the coaxial input is digital. The Mojo can't input an analogue signal and only recognizes a digital bitstream, this is why the sampling rate light turns off with the laptops headphone out plugged in. Remember, the Mojo is first and foremost a Digital to Analogue Converter, not an analogue to digital to analogue converter. You need to use a source that supplies a digital coaxial output or get a USB to coaxial adaptor to 'try out' the coaxial input. If you don't already have a coaxial source like a CD player or a DAP with coaxial output (like FiiO DAPs) it seems like a lot of effort to me just to test it.
