I'll let you know what color 2v is once I get my mojo 2 replacement.How do you do that, please?
Though it starts to clip at just over 4.3V so tbh you could just turn it up til you hear clipping then go down a few notches
Many thanks for this Rob, helpfulFrom my Mojo 2 presentation:
So for 2v you need to set both volume LEDs to indigo (that's the first colour above blue).
Thank you very much! I am not planning to connect my Mojo 2 with an amplifier but it's good to know.From my Mojo 2 presentation:
I fully and 100% agree!!Chord really needs to address the issue. As I posted before, the DACs should have been designed to mute when the USB synchronization fails. Ignoring the issue is naïve because all it takes is one user with an deep fitting universal or custom in ear monitor to file a lawsuit claiming hearing damage from the loud white noise...
https://www.macrumors.com/2022/05/17/apple-airpods-pro-amber-alert-lawsuit/
There is no “double amping” as has been explained numerous times in all the Chord DAC threads. The dac digital to analog conversion is also the integrated output, similar to all DACs, but unlike other dacs, there is no additional amp stage.In which case I would be double-amping. Not sure if this has any drawbacks. I haven't noticed any issues with SQ, but did notice the battery seems to drain a little faster.
What's certain is that the Mojo can be used on a desktop with a separate amp if desired.
Hi, I have no intention of connecting my Mojo 2 with an external amp any time soon, but just because I'm clueless, do you mean that if the Mojo 2 is connected to an amp and the volume will be set to "Indigo", there cannot be/will not be any loss in sound quality? Just trying to understandThere is no “double amping” as has been explained numerous times in all the Chord DAC threads. The dac digital to analog conversion is also the integrated output, similar to all DACs, but unlike other dacs, there is no additional amp stage.
Sincere apologies for not having read all the Chord DAC threads... and many thanks for taking the time to share this, I have learned something new today.There is no “double amping” as has been explained numerous times in all the Chord DAC threads. The dac digital to analog conversion is also the integrated output, similar to all DACs, but unlike other dacs, there is no additional amp stage.
No problem, I am also using a Chord product first time.Hi, I have no intention of connecting my Mojo 2 with an external amp any time soon, but just because I'm clueless, do you mean that if the Mojo 2 is connected to an amp and the volume will be set to "Indigo", there cannot be/will not be any loss in sound quality? Just trying to understand
I'll DM you.Can you DM me as well please? Or just post online as I guess many are interested : P
Thank you!No problem, I am also using a Chord product first time.
There no clipping or quality loss if you keep the volume on Mojo 2 below Indigo.
I am using it with my Topping A30 Pro.
No problem.Thank you!
I have one more question, this matters to me, if you or anyone else can enlighten me, I'd be grateful!!
How can I connect my Mojo 2 with my FiiO BTA30 Pro, so that I will be listening from my UTWS5?
Can this even happen?
What are the consequences to the sound quality?
Thanks a lot!
The chord DACs do have an additional output stage. You can see it on the PCB of the device and RW has also spoken a bit about the design of it on a few threads.There is no “double amping” as has been explained numerous times in all the Chord DAC threads. The dac digital to analog conversion is also the integrated output, similar to all DACs, but unlike other dacs, there is no additional amp stage.
So that means that the amp of the Chord Mojo 2 will be bypassed when i connect the headphone socket to my external amp?I use my Mojo 2 essentially as a desktop device.
As pointed out by msz38 above, all you need is a 3.5mm to RCA cable (I have one from QED, cheap and decent quality).
The amp is then plugged into the headphone socket and (I believe, not 100% certain on this) the Mojo 2 automatically goes into line-out mode.
On Mojo 1 you had to press the buttons in a certain way to activate line-out, but on M2 this is done automatically as far as I can tell.
My amp is the Lake People G109 and this set up works perfectly: Laptop --> Mojo as DAC --> G109 --> headphones.
To be honest I don't know how necessary this is as I've never had issues with the Mojo's built in amp, and the G109 isn't a TOTL monster or tube amp that is going to make a huge difference. But I like it.
My Mojo hasn't been out of the house since I received it and for all intents and purposes it's a desktop DAC/Amp to me. In my opinion this versatility adds a lot to its appeal.
I am not certain how it works in practice, and the feedback is somewhat contradictory:So that means that the amp of the Chord Mojo 2 will be bypassed when i connect the headphone socket to my external amp?
