amigastar
- Jan 18, 2011
I meant a DAC who you can connect to an amp.It's the Mojo 2.
I think Chord need a 600 bucks Anni without the speaker portion.Chord really needs a 600 bucks desktop dac in their lineup.
Why can't you connect a Mojo to an amp?I meant a DAC who you can connect to an amp.
If you can, could you link me to a tutorial how to do it?Why can't you connect a Mojo to an amp?
Does it not result in double amping?Why can't you connect a Mojo to an amp?
Hi @rlanger. Could you please point me to this thread where @GoldenOne shared his HQPlayer settings for the Mojo 2?Anybody else using HQPlayer with Mojo 2? I find this to be an absolutely remarkable combination, given that Mojo can decode PCM 768khz upsampled files.
Truly revelatory sound for me.
Unfortunately, the user experience of HQPlayer is garbage, but I found a workaround that allows me to use my preferred player on Windows, MusicBee, to stream to HQPlayer, which then outputs to the Mojo.
Highly recommend giving HQPlayer a listen. And thanks again to @GoldenOne for sharing your HQPlayer settings in another thread. It would've taken me a lifetime to figure out how to set it up otherwise.
Now if I could only figure out how to route Amazon HD Music to HQPlayer, I'd be all set.
As you wish:Hi @rlanger. Could you please point me to this thread where @GoldenOne shared his HQPlayer settings for the Mojo 2?
Thanks
Thank you @rlanger, much appreciated. Will have a play about with settings later.
Can you DM me as well please? Or just post online as I guess many are interested : PI'll DM you my comparison.
I use my Mojo 2 essentially as a desktop device.If you can, could you link me to a tutorial how to do it?
There is no line out mode (auto or manual) on Mojo 2.I use my Mojo 2 essentially as a desktop device.
As pointed out by msz38 above, all you need is a 3.5mm to RCA cable (I have one from QED, cheap and decent quality).
The amp is then plugged into the headphone socket and (I believe, not 100% certain on this) the Mojo 2 automatically goes into line-out mode.
On Mojo 1 you had to press the buttons in a certain way to activate line-out, but on M2 this is done automatically as far as I can tell.
My amp is the Lake People G109 and this set up works perfectly: Laptop --> Mojo as DAC --> G109 --> headphones.
To be honest I don't know how necessary this is as I've never had issues with the Mojo's built in amp, and the G109 isn't a TOTL monster or tube amp that is going to make a huge difference. But I like it.
My Mojo hasn't been out of the house since I received it and for all intents and purposes it's a desktop DAC/Amp to me. In my opinion this versatility adds a lot to its appeal.
In which case I would be double-amping. Not sure if this has any drawbacks. I haven't noticed any issues with SQ, but did notice the battery seems to drain a little faster.There is no line out mode (auto or manual) on Mojo 2.
How do you do that, please?There is no line out mode, though you don't explicitly need one.
Just adjust the output level to about 2v and you're good to go.
