off the top of my headband
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
I think you are going by hype!Maybe I expected too much from a portable device![]()
Figures from this site and that site, and a lot of people expressing opinions as facts, can throw anybody off.
I have a pair of Hifiman Edition XS. they are 18 ohms (loww!) and an efficiency of 92db (again loww), when some IEM's are in high 100db's.
I have read here and there that these cans Thrive on Power, more Power . some even claim it sounds better on 2W min. (W-T-F!).
Let's say Hifiman was very very conservative with their figures, and it is actually 89dB.
94dB is considered a high listening volume, let us say naa! a Rock concert at 109dB!
Let's do some calculation:
If the cans can produce 89dB at 0.001W (yes that is the definition of efficiency, for one milli-watt), then at 100mW they can go 20dB louder to 109dB (deafening).
Let's now say there is 3dB headroom on the recording, and another 3dB for peaks, we are now at 400mW!
@400mW the EDXS can hit 115dB theoretically, or a safe 109dB continuous. this is a low-effeciency can, and we allowed for Hifiman possible BS on yheir effiiciency figure, recording issues and musical peaks.
The 2W min. is just BS - why are people saying it then? - a lot of gear with 2W output are actually clean up to few hundred milliwatts only, so if one wants more clean power, they have to go for a 5W output!
Indeed Mojo1 and Mojo2 both can drive EDXS to really loud levels, without going into clipping.
Mojo (both) are small enough to fit inside your pocket (not shirt, or it drags to belly), has decent play time, and one of the best audio quality on the move anybody should want.
Ask some Rock musicians!
Definitely using the correct port.
I've made a quick video here:
Hello, do you have any update about this matter? What caused it, what did Chord Support say?
Chord said to take it to the dealer for a replacement, which I'll do soon. I'm heading to Munich on Thursday so won't be able to sort it til next weekHello, do you have any update about this matter? What caused it, what did Chord Support say?
Best of luck, I'm sure you'll get a replacement which will work fineChord said to take it to the dealer for a replacement, which I'll do soon. I'm heading to Munich on Thursday so won't be able to sort it til next week
Best way to listen to Flac files on Mojo2?
I have started ripping my cd collection to FLAC. Right now the files are stored in Dropbox.
What is the best way to listen to my music through the Mojo2? I am on an iphone. I have tried Mconnect but the tracks are out of order (metadata added via Foobar2000) and it's not able to access dropbox every time I use it.
paulrbarnard
- Oct 5, 2010
VOX works very wellBest way to listen to Flac files on Mojo2?
Chord really needs to address the issue. As I posted before, the DACs should have been designed to mute when the USB synchronization fails. Ignoring the issue is naive because all it takes is one user with an deep fitting universal or custom in ear monitor to file a lawsuit claiming hearing damage from the loud white noise...oh, I think I just reached a white noise issue aswell for the first time.
I was randomsly watching some videos and then suddenly a huge white noise as soon as a sound needs to be played.
I had to turn off and on my unit to solve the issue. I hope everything will be fine for the next days or I will probably return my unit then to be fixed.
https://www.macrumors.com/2022/05/17/apple-airpods-pro-amber-alert-lawsuit/
Anybody else using HQPlayer with Mojo 2? I find this to be an absolutely remarkable combination, given that Mojo can decode PCM 768khz upsampled files.
Truly revelatory sound for me.
Unfortunately, the user experience of HQPlayer is garbage, but I found a workaround that allows me to use my preferred player on Windows, MusicBee, to stream to HQPlayer, which then outputs to the Mojo.
Highly recommend giving HQPlayer a listen. And thanks again to @GoldenOne for sharing your HQPlayer settings in another thread. It would've taken me a lifetime to figure out how to set it up otherwise.
Now if I could only figure out how to route Amazon HD Music to HQPlayer, I'd be all set.
I may be late but it might be you didnt push your usb cable all the way in.Hello, do you have any update about this matter? What caused it, what did Chord Support say?
I noticed there is a double click for the usb ports in my M2 especially the usb C connector. There is a first click when you push it in but you'll need to push it in further for the 2nd click.
This also may be causing the white noise issue if you input cable are not pushed all the way in.
amigastar
- Jan 18, 2011
Hey guys,
got a question. Is there Dac from Chord that sounds like the Chord Mojo 2 but is a desktop Dac?
I've listened to the Chord Mojo 2 and I really liked it. I mean for 600-700 bucks.
A used Qutest is probably the closest product in their line and your budget.Hey guys,
mariopoli
- Mar 12, 2009
Chord deserves to get sued. This is a terrible problem with their product. For me I solved the problem by always having some sort of dongle between my Source output and the Mojo2 input. They should at least tell their customers to do this.Chord really needs to address the issue. As I posted before, the DACs should have been designed to mute when the USB synchronization fails. Ignoring the issue is naive because all it takes is one user with an deep fitting universal or custom in ear monitor to file a lawsuit claiming hearing damage from the loud white noise...
amigastar
- Jan 18, 2011
Chord really needs a 600 bucks desktop dac in their lineup.A used Qutest is probably the closest product in their line and your budget.
It's the Mojo 2.Chord really needs a 600 bucks desktop dac in their lineup.
Total: 48 (members: 10, guests: 38)
