Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Oct 17, 2015 at 9:06 AM Post #707 of 42,765
Oct 17, 2015 at 9:36 AM Post #709 of 42,765
Would love to hear from any Windows Phone users who have got the Mojo to work
if so this is the worlds first USB dac that works with them
Oct 17, 2015 at 9:52 AM Post #711 of 42,765
it's been designed for phones in the first instance mate...
Oct 17, 2015 at 10:24 AM Post #713 of 42,765
Windows Phone is a VERY closed environment, and I don't recall seeing any USB supporting apps on the windows store when I had my Lumia 930 :frowning2:
Oct 17, 2015 at 10:24 AM Post #715 of 42,765
Thanks, is there any list of supported devices? Cause Chord Electronics site says: [COLOR=000000]"It works with your iPhone, Android or Windows phone."[/COLOR]
[COLOR=000000]"[/COLOR]Android tablets and phones that conform to the OTG standard." As far as I know S5 and S6 does support OTG.
You need an app like the Onkyo Hp to output to the mojo either on android or idevices. No Tidal on android but works on idevices using the CCK cable.
Oct 17, 2015 at 10:25 AM Post #717 of 42,765
Mojo development had some weird fortuitous events - the first time we showed the prototype happened to use the only 8 ohm headphones that would show problems - and the day we were deciding on the design Xilinx emailed me with a new FPGA that would enable Hugo performance but with the needed power, and happened to be in production just in time for Mojo.
Hi Rob! So does the new FPGA mean the Mojo has the same number of taps as the Hugo despite its smaller size? And can you foresee whether the TT will evolve and exploit the new FPGA? I'm a bit confused at the moment - it seems like the Mojo has a better noise performance than the TT. I can't imagine you would want it to stay that way.
