Thank you guys, really appreciate your help.
Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
Lacas
- Dec 4, 2013
i have the same cable. it only works with such players that have shared usb/spdif output. primarily Cayin and Hiby dapsHello,
I have try to use my Cayin USB C to coaxial cable with the Mojo to connect to my pixel 6a, but I can't get no sound. I'm using the USB audio pro app, do I need to change any configuration on the app side?
Thanks!
RiseFall123
One of my two Chord Mojo's stop working in USB. It correctly turns on.
There's something I can try myself?
I already try another cable and another source.
Rei7
- Sep 17, 2012
Any of you guys know why I can't hear to Discord app audio on voice chat with the Chord Mojo? It's all set up just fine, and I should hear an audio source from it. For some reason there is no audio at all just for this specific app. There isn't any issue while I listen to music, watch videos or any other app.
Did you check the Discord settings for the output device?Any of you guys know why I can't hear to Discord app audio on voice chat with the Chord Mojo? It's all set up just fine, and I should hear an audio source from it. For some reason there is no audio at all just for this specific app. There isn't any issue while I listen to music, watch videos or any other app.
Discord is rather picky and sometimes needs the output to be defined, else if you use default, it may not go through the Mojo.
Happened to me a few times before.
Rei7
- Sep 17, 2012
Yup should be but still no sounds which is weird really.Did you check the Discord settings for the output device?
EDIT: It works now, I think it might just be the cable I'm using. Bought a better quality cable and all seems well.
magicalmouse
Hi, i had a similar problem and you could try another cable but it is more likely to need the socket resoldered by Chord, this is reasonably priced (uk) and cost me around £50 for all the sockets to be checked and fixed.One of my two Chord Mojo's stop working in USB. It correctly turns on.
d
Mangodango369
I wonder if there is a reason why mojo 2 does not come with 4.4mm...
captblaze
It was deemed unnecessary by the designerI wonder if there is a reason why mojo 2 does not come with 4.4mm...
Mangodango369
I see, oh well... maybe costs will increaseIt was deemed unnecessary by the designer
headmanPL
In the Mojo 2 thread Rob Watts discussed that topic this week...I see, oh well... maybe costs will increase
https://www.head-fi.org/threads/cho...ing-on-page-95-of-thread.885405/post-17614049
What's the point of a balanced connection, on a single ended device?I wonder if there is a reason why mojo 2 does not come with 4.4mm...
Its like wondering why an electric car doesn't have a tank!
4.4mm sockets are for balanced connection only.
Rei7
- Sep 17, 2012
Hey guys, any recommended OTG for the OG Chord Mojo? Using a Samsung S22 Ultra atm.
I've always only exclusively use the Mojo on my desktop, and don't really have any portable setup experience sadly.
EDIT: Went with the ddHifi TC03, works great!
imackler
- Nov 17, 2008
Hello! Does anyone know where to find a micro usb to lightning cable that bypasses the need for a CCK cable for use with iphone/ipad and mojo 1? The CCK isn't bad but one cable is more... elegant. Thank you!
miketlse
- May 8, 2016
Here are a few posts for you to reviewHello! Does anyone know where to find a micro usb to lightning cable that bypasses the need for a CCK cable for use with iphone/ipad and mojo 1? The CCK isn't bad but one cable is more... elegant. Thank you!
Total: 26 (members: 0, guests: 26)
