jdpark
- Jan 14, 2014
Well yeah, any Chord enthusiast knows that. What I'm saying is that the amplification in Chord DAC/amps is not going to compromise the sound quality when connected to another amp, so although it's technically double amping, it's not "conventional" double amping. This is a crucial distinction, because many amps do color the sound when used as preamps.
I don't understand why people keep going over these points. The Mojo has a headphone amplifier setting, and a line out setting. You should not use headphones with the line out mode, and you should not send the analogue signal to an external amp in the headphone amplifier mode. This is very clear in the manual. No one who uses the line out would be considered "double amping".
Obviously, being the experimenter that I am, I've tried using the headphone amp mode for powering an external amp, such as the Schiit Magni. It gets distorted and doesn't sound good. Yet, when using the line out mode, it sounds great. But by all means, this is a thread where everything worth saying, is worth saying at least 50 times.
