Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12102118
Post #5,746 of 40,457
WCDchee
Wonder if Chord/Rob Watts can advise what the Mojo outputs into 100ohm?
Based on 5V maximum it should be up to 250mw thereabouts. Not to worry though the mojo can power just about anything :)
post-12102148
Post #5,747 of 40,457
TomGi
I am using the AK120 Titan via optical out and using the MH335DW.
And as I stated, it is not hissing, it is a buzzing. It happens even when the Mojo isnt connected to any source, and it is more prominent on the right channel and its not very slight, its actually very noticeable and can even be heard in the opening of songs where the music is a bit softer (not just in quiet passages). Is this a defect? should I bring it back?
Yes. Your Mojo is faulty as my first one. You should bring it back to get a new one.
post-12102151
Post #5,748 of 40,457
NZtechfreak
Yeah, I'm aware of that (although my HE6 need more) - was using it with the LCD-4 over the weekend just gone, was just curious exactly what it was putting into them. Thanks!
Checked - LCD-4 needs ~100mW to reach peaks of 120dB, so plenty of headroom. Another guy was saying he had the Mojo at max volume with the LCD-4 and was hearing clipping, which didn't match with my impression at all. Wonder how long his hearing will hold up given the volumes he listens at...
post-12102186
Post #5,749 of 40,457
sandalaudio
Sound quality debate aside, I could use the Mojo to drive LCD-4 or HE1000 etc without sounding compressed or distorted, even on fairly quiet classical recordings. It had a bit more headroom in the volume position.
Then again, I was at a shop last week and this guy was doing a demo on an HD800 with music so loud that everyone else thought that he forgot to plug it in and the music is coming out of the floor speakers.
It told me two things:
1. Some people do listen crazy loud without care, so we have to treat user reviews with a grain of salt.
2. HD800 sound amazing as a pair of loudspeakers.
post-12102224
Post #5,750 of 40,457
WCDchee
In fact, according to Shigzeo's measurements (if I didn't interpret it incorrectly), as you push the volume up, the mojo actually gets better. It's measurements at max volume are pretty sick.
post-12102268
Post #5,751 of 40,457
salla45
Just listening to 70s Steely Dan on Mojo+K3003's. A very fine combination.
There's just so much more happening within these well loved albums than ever I have heard before.
Steely Dan were known for their obsessive production and perfectionism back in the 70's. I know these albums inside out. Top albums for me for the past 30 years. Regular replay.
Pretzel Logic is really shining, really VERY 3d. There's some mad juju going on here.
Night by Night's lead guitar has a texture I've never noticed before. Rikki Don't Lose That Number has that vibrophone intro to it, which I had NO IDEA continued into the main track. Never hear that before.
Wow... it's really like listening to complete new masters of stuff...
Go Mojo!!!
post-12102273
Post #5,752 of 40,457
Torq
Seattle, WA
Seattle, WA
So it's entirely normal that when used as a DAC for iMac the Mojo's ability to display different colors according to sample rate differences is effectively disabled and it will simply forever be at the color corresponding to the maximum rate you set it on in the MIDI setup.
Should I set it to the maximum (7xxHz) just for maximum leeway or just to 192 since that's the top rate for most tracks? Is there an advantage to picking one over the other or does it simply not matter.
There are various audio players, and add-ons, that will automatically reset the output sample rate based on the track you are playing. "Bit-Perfect" will do it as an add-in for iTunes, then there are other players like Amarra, Audirvana, Fidelia, JRiver Media Center, Roon and so on that'll work either with iTunes, standalone or both (depending on the player) that will manage the output sample rate automatically.
Having the rate set correctly to match the source file avoids having Core Audio up/down sample the file. Some of the players I mention above offer better resembling implementations. Personally I prefer not to up sample ahead of the DAC if I can avoid it.
post-12102287
Post #5,753 of 40,457
shigzeo
The Hiss King
Website
ohm-image.net
That's a general measure of output. Signal to noise, stereo separation, etc., are directly related to pre-gain volume. 24-bit allows for more usable volume, that's it.
post-12102313
Post #5,754 of 40,457
Rob Watts
Member of the Trade: Chord Electronics
Just a thought. Why do other DAC/headphone amps have amp sections when Hugo/Mojo get by without one, and many including Chord say it is more transparent? Have Chord got the patent for ampless amps :)
Because they can't using chip based DAC's. Chip DAC's have two current outputs. So you need two I to V converters (amps) then a differential to single ended amp, then a headphone buffer to deliver the current. You also need a lot of analogue filtering wrapped around these amps. So why are normal DAC's so complex in the analogue domain? Two reasons:
1. Silicon DAC's are horribly noisy, as the substrate and grounds are bouncing around due to switching activity. So to counter this, it is done differentially, which means the ground noise is cancelled. It also hides the problems of the reference circuitry, which can't be made with low enough impedance on silicon. This translates to more distortion, and crucially noise floor modulation.
2. Delta sigma converters run at low rates - best is at 12 MHz - this means that there is a lot of noise that must be aggressively filtered out in the analogue section. This also applies with R2R DAC's too as these have even worse problems due to the very slow switching speed.
So to run with a single amp section you need the DAC to be single ended and to run the noise shapers at much higher rates to reduce your filtering requirements. Because the analogue section with Mojo is discrete, I can use extremely low impedance and low noise reference supplies - something that is impossible on silicon. This has the other benefit of eliminating noise floor modulation (actually there is a lot more to it than this as there are countless other sources of noise floor modulation in a DAC). To make the filtering easier, the pulse array noise shapers run at 104MHz - over an order of magnitude faster than normal. There are other benefits to running the noise shapers at 104MHz, principally the resolving power of the noise shaper. Now soundstage depth is determined by how accurately small signals are reproduced. The problem with noise shaping is that small signals get lost - any signal below the noise shaper noise floor is lost information. But by running the noise shaper at much faster rates you solve this problem too - indeed Mojo noise shapers exceed 200dB THD and noise digital performance - that's a thousand times more resolving power than high end DAC's.
If I get time today I hope to publish noise floor modulation measurements showing Mojo has zero measured noise floor modulation. This level of performance does not happen on any other non pulse array DAC's at any price, and its the primary reason why Mojo sounds so smooth and musical.
Rob
post-12102340
Post #5,755 of 40,457
FALEEV
Moscow
Moscow
Rob
So, does Mojo have better noise floor modulation measurements than Hugo or they are the same?
post-12102353
Post #5,756 of 40,457
obsidyen
Cambridge, UK
Cambridge, UK
  Here's a great Japanese axiom that may explain Mojo's brilliance: "Simple is best".
"Simplicity is the ultimate sophistication."
Leonardo da Vinci.
post-12102362
Post #5,757 of 40,457
shigzeo
The Hiss King
Website
ohm-image.net
post-12102397
Post #5,758 of 40,457
nntnam
Rob
I would love to see more of measurement of the Mojo :D .
I just pre-ordered it, has to wait until mid-December :frowning2: . Somehow it's out of stock everywhere in Japan... Hope my unit won't be so hissy with Fitear earphones. Hiss was the main reason I sold CypherLabs Theorem 720.
post-12102414
Post #5,759 of 40,457
AndrewH13
CanJam London 2017 Ping Pong Champion
Southend, England
Southend, England
1. Silicon DAC's are horribly noisy......
Rob
Thanks Rob for such a detailed answer. And to others that replied.
Better lock your code up Rob, under lock and key☺. Seriously though, with you being so open on all your discoveries in the digital domain, is there any worry of competitors copying, or replicating your code? Is it covered in a legal way, patent etc or is it that it would be impossible technically for others to use?
post-12102431
Post #5,760 of 40,457
shigzeo
The Hiss King
Website
ohm-image.net
The Mojo's price point will be a huge deterrent to competitors that want to copy. It is finely machined, tight, and performs nearly flawlessly. Had I handled it and measured it without being told its price, I probably would have guessed around 1000$.
Users Who Are Viewing This Thread (Users: 2, Guests: 10)
  • Top
