Mojo LO mode is just line level voltage output(or volume level that matches the line level voltage, which was the same for the Hugo). The difference from a dedicated DAC compared to pre-amp is, with a pre-amp you are making adjustment to the output voltage that the receiving amp takes in to drive whatever is being driven. Output impedance of dedicated amp is higher than something like a mojo. Ideally, you want want an amp at the driving side to lower the output impedance which the dedicated amp is too high, and therefore you send the DAC's signal to the amp that lowers the output impedance.
Line-level output of a dedicated DAC is amp'd. With a dedicated DAC, although you can adjust the volume digitally by software, the output impedance is the issue which is reduced with an amp.
Chord DAC/amps are also digital preamps. The output voltage is adjusted by the digital volume control whether you are driving headphones or connecting to a speaker system.
(Just wanted to clarify, since your statements could be interpreted as saying otherwise. Oh, and I didn't mean they're preamps when you're driving transducers directly.)
What I'm most concerned about is the noise I'm hearing with a dirty usb connection out of my desktop. With the Mojo, I feed in optical which isolates from such noise. Behringer UCA202 seems to be low cost option to isolate usb noise if you don't have an optical out on your computer.
Yep, I was happy with using the UCA202 that way (the Mojo is the only DAC I tried optical with), and at the moment it's my temporary DAC as well.
I had a set of passive loudspeakers in the past that I no longer own, and looking into getting a new pair(which performs very well from what I recall, and there is a difference from monitor(like JBL 305) output to what a loudspeaker can do). And the Behringer KM750 sounds like a very reasonably priced option to get ample power fed to them.
I had these, and these(mine were EMP tek, but same thing) were impressive for the price.
https://rbhsound.com/towers_imp.php
I think I'll focus on Tekton speakers from now on. The designer claims they're the most accurate speakers in the world despite the (relatively) affordable prices. I don't know how true that is, but the reviewers (and owners) are going crazy over them. The description of the technology is very interesting:
http://www.tektondesign.com/about.html
JBL 305 can output clean sound, but it's not only about loudness in a space that loudspeakers do better compared to a monitor. If you compare loudspeakers to these monitors, you will notice the differences. It's not really about speaker size fitting for room sizes, there is more to it than that.
Studio monitors are loudspeakers too. Technically, all sorts of speakers (active, passive, small, large, etc.) can be studio monitors; it's just that many of them tend to be powered and compact. In some cases, the exact same floorstanding speaker with a different paint job / finish has been marketed as either a studio monitor or audiophile speaker.
And yeah, my towers sound way more realistic than the small monitors, but they're both great.
How did you run into the Behringer KM750?
I just researched affordable power amps.
The main downside (aside from its size and weight) is the loud fan system. It stays cool, but is not quiet at all.
I plan on sticking with it until I can get a digital power amp from Chord when it's released. (People are saying it will be like the speaker version of basically being able to drive headphones directly from the DAC, with the highest transparency/accuracy.) On that note, I'm still curious how well Chord DAC/amps can drive various passive speakers directly, since you can do that with the right cables. They're just limited in output power, so the speakers have to be fairly sensitive.
