Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
May 27, 2017 at 9:13 AM Post #32,417 of 42,765
X5 v3
May 27, 2017 at 9:23 AM Post #32,419 of 42,765
Fiio L21 3.5mm to rca Coaxial digital adapter cable cable to the cable that came with the x5
May 27, 2017 at 10:57 AM Post #32,421 of 42,765
AFAIK the L21 is just a longer version of the cable (except with a male RCA) that came with the X5 and is not suitable to plug directly into the Mojo.
The cable you need with the X5 adapter would look more like this: https://www.amazon.co.uk/m-one-Black-3-5mm-Single-Phono/dp/B01MTFVT9T
Or a normal coax cable plus one of these: https://www.amazon.co.uk/kenable-Phono-Socket-3-5mm-Adapter/dp/B004HSQJHY
I don't actually recommend either of them, I just linked them so you could see the sort of thing that might work, though I think I have used the second one successfully in the past.
In either case, it is a mono jack plug, not a TRRS at the Mojo end.
I actually use a Penon cable which is designed specifically for the X5 to Mojo connection and don't bother with the adapter.
This is the one - the 4 pole plug is the one I use: http://penonaudio.com/Coaxial-Decoding-cable-for-Chord-Mojo-with-DAP
May 29, 2017 at 12:29 PM Post #32,422 of 42,765
Hi all!
A while back I saw an Excel sheet that listed the volume levels and their associated colors, but now I can't seem to find it. Can someone please point me in the right direction?
Thanks!
May 29, 2017 at 2:04 PM Post #32,423 of 42,765
Hi all!
Thanks!
Hey there,
Go to page 2065, third post.
Cheers
May 29, 2017 at 5:00 PM Post #32,427 of 42,765
I only did a quick Google search, but near the mentioned post was also a sheet created by Grumpy, showing volumes for several headphones...
Cheers
EDIT: If you want to know the Volume of your headphone at a given Mojo colour indication, Grumpys approach explained in the post is IMHO the best way.
May 29, 2017 at 5:40 PM Post #32,428 of 42,765
I admit I can't see the need to have such a thing. Just put it low and then gently lift until it's a comfortable volume. What's the need for a spreadsheet? :confused:
