SomeGuyDude
- Jun 24, 2012
Several members around here also insist that $800 cables are worth it and that they can tell MQA from FLAC, so watch out.
You should get a Synergistic Research HOT.
Mojo will convert digital to analog when you connect your phone via OTG cable.
The next question is : Will it be bit perfect or will Androids upsampling process interfere
For bit perfect Tidal playback on Android many use the App UAPP ... not 100 percent sure about Spotify, since I don't have it.
Cheers
Is there any comparsion with centrance dacportabe (Im the owner) ?
I think this question was discussed but with this new forum style I cant find option "Search this forum"
Im going to use it with Iphone 7.
Yes, but you only can stream Tidal.+1 UAPP is a must-have app for android. For the functions and ease of use it is a bargain!
I will do.Take a look at the Onkyo DP-X1 and DP-S1 as well.
I will do.
Do you know if both of them or at least one of them allow digital output to Mojo preferably coaxial?
