GreenBow
- Feb 6, 2015
I use my Mojo as a desktop DAC but I use it on battery and charge overnight. Sometimes I need a little charge and play. (However it doesn't shut down when doing that.)
Ideally a mains powered desktop DAC would be preferential, but I'm OK with the Mojo. It would have been nice if the Mojo had a longer battery life. Meaning it would be enough for daily use for those using it all day.
I did think of a solution to make the Mojo mains powered though. Remove the cover, and unplug the battery. Attach a PSU supplying DC at the right voltage, to the power socket on the Mojo circuit board. (Right voltage being whatever the battery puts out when fully charged.) Modify the case to take the PSU DC cable.
Should work.
Should work.
