Did a quick search and there are dedicated glasses for colorblindness, which are supposed to help in general, not just for red/green.
They are called enchroma.
So I've set myself the challenge of reading this thread before deciding whether to get a Mojo or not. There's a little bit of my subconscious that's currently busy convincing everything else that I need one, and getting one in the same month as ordering a DJI Mavic (drone) isn't exactly compatible with marital bliss.
I'm currently about forty pages in.
Did a search to see if anyone's asked a similar question, and it seems not. My current setup is all Bluesound-based (it's basically 'posh Sonos', made by the people behind NAD). My 'sitting at my desk, working' headphones are Audioquest Nighthawks, which I like very much (and which I gather pair very well with Mojo). I'm using the headphone amp that's built into the Bluesound Node 2. Detailed info about the headphone circuitry is hard to come by; when I asked their support what sort of level its performance was at, the answer I got back was:
Our Gen 2 Players feature a dedicated headphone output driver. The driver is rated 0.0055% THD @1kHz, 35mW. It is designed for use with most headphones, with a minimum impedance of 14 ohms.
For some ideas on how our Headphone Output compares to other media players, we would recommend that you contact your local Bluesound Authorized Dealer for recommendations and comparisons.
Does anyone have any idea how much of a step up in performance I am likely to experience moving from a Node to a Mojo? Will likely be using coaxial out from the Node.
