- Mar 16, 2009
Audiostream also did a small USB cable shootout: http://www.audiostream.com/content/usb-cable-shootout. Interestingly enough they chose the Synergistic Cable as having the best synergy with the MSB Analog DAC which some have compared to the Hugo. If it makes sense at all, I also actually think the SR has a similar "analog" sound signature.
I'm also interested in hearing about the Metagenome cable as I really like DHC and I thought their USB cable had amazing aesthetics. But, as you said, it's got to be heard.
In your price range, I would easily go for the AudioSensibility Statement cable--easily. It is fluid and transparent (definitely, all the high end cables were). It was the best bargain of the group as it was of the same quality as the others for a fraction of of the price. In the same price range, personally, I find the Wireworld offerings are "harsh and bright." Again, personally, I didn't like the Lightspeed at all for the Hugo, esp. for $1K.
Also, FYI Steven at AudioSensibility offers a 30day money back guarantee, so you can hear it for yourself. Just a word of caution, after the Hugo, which is a something of a "bargain," these pricey enhancements are not going to yield the same ratio of cost to SQ. You are paying quite a bit to gain and fine tune the last 5-20%. I say that because I've found a sort or "audiophile linearity phenomenon," i.e., once you hear it you can only go forward, you can't go back! Apologies for starting off 2015 leaking £££'s, from one who leaked his own $$$'s in 2014.
Cheers, looks like I've plenty of reading to do tomorrow then!
I had DHC cable do me a custom made cable for my old AKG702's back in the day when he had not been going too long and the quality was second to none with the build with really close eye to detail not to mention also how patient he was with back & forth discussions on the type of cable, materials and aesthetic design. It took my 702 sound to another level to the stock and regretted letting it go for just the cable alone! And from what I see a few years on, the quality is still there so will be on the long term high end short list of USB cables for sure.
Iv'e not been to impressed with Wireworld cables to much, had their mains power Electra's, Silver+ HDMI's and tried some of their analog ic's. I know their actual mains cable (Electra 52 gold) they use is actually quite good but is let down by the quality of the way the plugs are done which negates the whole objective of improving performance (the irony is almost lost on me). Also it does seem to me for some of the big well known mainstream hi-fi cable manufacturers to make cables sound harsh and bright like it is a fashion statement to have top end systems sounding like this is good. Surprises me more as Wireworld is USA manufacturer and I thought it was just the UK company's going this route. This is why I love my Chord Indigo cables as they do not sound like that and have a balanced, open, articulated presentation with just have a touch of warmth with non harsh top end but same time they are expensive and to fit my Indigo digital coax into the Hugo for example I now need to send back to them to re-terminate plugs to fit! Such is life : )
Yes, I'm a veteran of the diminishing returns for price to performance ratio with my speaker Hi-Fi down the years. A lot of Chord ic's add's up to a good second system alone!
It is amazing how much that extra last 5-20% makes to a set up. I never thought mains cables would make a difference especially after a bad first time experience with some fairly expensive ones from 1st gen Chord mains cables (although I love their Indigo's/Signature cables) these were awful!
....But got rejuvenated recently by some that didn't cost the earth custom parts picked by me and made by someone else as I'm not clever, more dangerous with electrics and soldering!) and could not believe how much difference they make in my Hi-FI set up.
When done wrong I can see why "snakeoil" tag is thrown around, if done right it is noticeable with enough difference to justify the smaller % performance gained to higher price outlay.
So... experience has taught me a good cable half the price will out perform a bad cable costing twice as much...why it is such a long painful journey sometimes for little return but the pain is fun at the same time!?
So comes back around to hearing them is proof in the pudding for exception of it is harder with the boutique ones found around these parts but getting to my point of as I've decided I will use my laptop a lot now to listen to the Hugo with I would be prepared to go higher end of the cost scale if there is another 10% to be had. Just right now it will probably have to be around the £200 limit which I am sure there are plenty out there that would bring a smile to my face over a stock usb.
The leaking £££'s not for the USB cable as I thought at some stage I might have to spend a bit on a USB cable for the Hugo but the Audiophilleo converter thing? If that is a viable partner that will improve things further paired with the Hugo later on then that is the £££'s I did not see coming. Like a Hugo crash waiting to happen! ... Do you own a Philleo yourself or just heard it?
Good to hear Audio Sensibility do the 30 day thing, maybe that's were they get the "Sensibility" in their name?
Anyway, although talk about cables this will go towards finding a good partner to bridge the laptop to the Hugo for some serious listening and ween me away from my ZX1-> Hugo partnership for HP sessions.
