Hello Rob,
Here are a couple of questions about the digital volume control and plugging the Hugo directly to a power amp. I'm puzzled by these and I'm sure others are too.
I followed your advice on connecting the Hugo to a power amp - my amp (Classe Cap2100) is integrated but has an HT bypass mode - that is essentially a power amp. I think it sounds better but not sure.
When used in this mode than the amps volume control doesn't work (obviously) so I use the digital volume control (via Jriver) to reduce the volume and change it as needed - I'm too lazy to go us to the Hugo every time...
My Hugo is connected via Toslink to the computer.
My question is how much can you lower the digital volume control (in Jriver bit stream) before we start to introduce distortion? I've seen people suggest that up to 20% of the volume but you are the expert...
Thanks!
