- May 9, 2011
But thankful for the price point. Some people would pay more, but a lot won't. What they should do is remove BT.
You bought the Hugos from the CustomCable sale?
OK-Guy, they're having a sale. I think the correction, if any, will come in a few weeks when the novelty wears off and Hugo owners decide if they want to live with it permanently.
The first batches of the production units had smaller RCA accesses there are now plenty of cables that fit these. From the chord cable co and moon audio being two of them.Are there any other chassis? What's original chassis?
They also have a blurb at the bottom that states they can ship to US. Despite the new statement.
In my opinion, the BT "problems" are a non-issue. It's not vital to the function in any way, nor is it even an optimum method for listening from a quality viewpoint. Pure convenience. I would still have bought it at original price, and still maintain it's a good value sans BT.
Pretend it's not on there, then it becomes more like every other device, but sounds better.
Totally agree, BT output hardly worth mentioning from quality perspective surely!
The whole BT thing is like if Mercedes-Benz working really hard to bring out a sport-luxury, S-class, with unheard-of features, easily valued over $100K, but they sell it at $30K instead. But to top it off, they throw in spill-proof cup holders, that no one else has, for free, and you walk away from the whole deal complaining the cup holders don't hold bottles of Dom Perignon.
BT is there for convenience to pair up with a source wirelessly when moving around for example. It is also part of the original design and the fact it supports aptX and has a huge sticker on the bottom with aptX on it. I won't be using BT much since quality is not as good as from the other inputs but when carrying it around and listening there's no better solution if I need to use my mobile phone at the same time and don't want to wrestle with wires. I may only clock up 1% use with BT but I would at least like that use to be satisfactory and no worse than any other alternate BT product.
I think you have mis-understood him, HUGO supports DSD natively and when he says feed the desktop via RCA he meant use the RCA out of HUGO to connect it to an external desktop amp and test whether you get the same issue (assuming the amp use has silent background).
I know that the Hugo accepts DSD natively as an input. What I wanted to know was whether it converts DSD to PCM during its processing or keeps it as DSD the entire time until its converted to analog for output.
I plan on using the Hugo for both portable and home use in my main system.
Hmm. Not an easy question to answer. Firstly an explanation of the pros/cons of the formats:
1. PCM Pro: excellent resolution of small signals, very small signals do not disappear into the dithered noise floor.
Cons: Timing. Ear/brain can resolve 4uS, CD innately is at 22uS.
2. DSD Pro: Samples at 0.34 uS, albeit at not very good resolution, so has much better timing innately
Cons: resolution. Noise shaper noise is not the same as dithered noise, any signal below noise shaper noise floor is lost.
Now the timing issue can be resolved by the DAC interpolation filter, and with an infinite tap length filter, timing is completely reconstructed. So red-book is capable of very much better performance, if you improve the interpolation filter. But with DSD, the encoding means that low-level details are lost in the noise shaper noise floor, and they are lost forever. So DSD has a compression in depth and instrument separation, due to poor resolution, but does not innately have timing problems. Check out 2L website, and compare the DXD recording to the DSD64 or DSD128 - to my ears, the loss in transparency of DSD is not small.
Getting back to design of the DAC. Now I run my DAC's with a very simple single stage active analogue section, with only 2 caps and 2 resistors in the direct signal path - and I do this for transparency. But this means the digital RF noise in the 100k to 1M band must be very low, so the digital source must be filtered - and DSD is at -20dBFS at 100kHz. So I can't put raw DSD into the DAC, or it will sound very hard. So the DSD is filtered, which converts it to regular PCM.
If I were doing a DAC for only DSD would I do it this way? Yes, I think I would, as simple analogue is always the best.
Incidentally, the DSD filters on Hugo has been improved - they are much smoother than with Qute.
Yes. But.. I have heard awful DSD's compared to regular PCM, and awful PCM compared to DSD. So if the recording started as DSD, stick to DSD and vice versa.
The 2L website does allow us to hear DXD (352.8 kHz PCM the DSD master tape if you like) against DSD, and you can hear the losses that DSD gives. And if I were not using a DAC with a WTA filter, I guess I would prefer DSD every time. So like most things in life, it all depends!
