Chord Hugo
post-14910911
Post #15,421 of 15,518
miketlse
I'm thinking of getting another power supply/charger for my hugo. It originally came with 11v 1.0a charger, just wondering does a 12v 0.5a work in this case as I can't seems to find a 11v 1.0a replacement? Need some advice here. Thanks.
I know that the Hugo has been out of production for 4 years, but are either of @Rob Watts or @Matt Bartlett , able to suggest a good power supply for this owner?
post-14912203
Post #15,422 of 15,518
Maidstone
Maidstone
Website
www.chordelectronics.co.uk
12V 0.5A with 2.1mm x 5.5mm barrel connector will work. Just make sure it is a switched mode type of power supply rather than a linear. You can use higher current so 1A, 2A, 5A are all ok. It is the voltage that is important so you must make sure the voltage cannot go higher than 12V.
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-14912353
Post #15,424 of 15,518
miketlse
Thanks Matt.
post-14912374
Post #15,425 of 15,518
Maidstone
Maidstone
Website
Thanks for the response @Matt Bartlett
Why switch mode instead of linear power supply ?
Thank you
Because in general switch mode power supplies are better and controlling (regulating) the output voltage under different loads compared to linear power supplies.
This is important for products like Hugo where the amount of load (current) varies depending on the charge status of the batteries. When we tested some linear power supplies
we found that during trickle charge the load was not enough to keep the voltage at 12V and it increased a level that could cause damage.
post-14912464
Post #15,426 of 15,518
xXOnGXx
Singapore
Singapore
Thanks, so am I right to say that it's okay to use a 12v charger even though it originally came with a 11v charger, the increase of 1 volt is fine?
post-14913209
Post #15,427 of 15,518
Maidstone
Maidstone
Website
Correct yes 12V is fine to use.
Reactions: xXOnGXx
post-14913681
Post #15,428 of 15,518
chesebert
I would not use third party charger. The cost of replacing the battery is prohibitively expensive.
post-14915845
Post #15,429 of 15,518
mathi8vadhanan
If you're using third party ones, make sure to verify the voltage with a multi-meter before plugging into Hugo. Some are rated at 12V but might be way-off like 14v, which would trip the Hugo protection circuits. Also make sure it's center positive.
Reactions: xXOnGXx
post-14915853
Post #15,430 of 15,518
mathi8vadhanan
post-14925780
Post #15,431 of 15,518
xXOnGXx
Singapore
Singapore
post-14932615
Post #15,432 of 15,518
VictorRad
Hi All
I'm a happy owner of Chord Hugo 1 but this DAC is not really portable so I'm looking for a music player which has similar sound signature and sound quality as Hugo 1 but more portable. Please make your suggestions.
post-14932646
Post #15,433 of 15,518
Whazzzup
Toronto, Canada
Toronto, Canada
The only dap I have tried is ak 380, ak with oversampling and what not is warm or smooth. Very appealing but not chord analogue transparency so, no help from me.
post-14934488
Post #15,435 of 15,518
AndrewH13
CanJam London 2017 Ping Pong Champion
Southend, England
Southend, England
Hi All
Questyle QP1R is closest I've heard with a clear upfront sound. iBasso DX200 Ti (limited edition) is better still, but only 66 made. Some being offered now DX220 being released.
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
