well... good power supply require more expense + more expense for bigger casing = less profit.
Well, as I said, it has already been done, in the same casing.
I just noticed this post. I recommended a friend to buy the Qutest and he complained of the same problem. I ended up referring him to YouTube review videos online to see how things are set because I’m too allergic to his cat to help him set it up and I don’t own a Qutest. What I found out later was that when you turn on Qutest, it cycles through the colours because that’s the time for setting the DC servo but that has nothing to do with the voltage settings and my friend was confused that he can press the buttons to set the voltage during this time. He was also holding onto the Filter and Input buttons either indefinitely or he’s watching the color change and pressing the buttons super quickly. I believe you’re supposed to press them and see the color change. If it still seems confusing, it’s best to see those YouTube reviews as to how the voltage is set.Got it, but using colour as indicator for voltage out may seem not to be optimal. There should be a dedicatet bulb for the v-output. That would make things intuitivet. That said; not a fan of the bulb and collours, Change it wih a more direct display; Let say a red letter 1v etc. Cryptic display is not a good thing. Gives me a headache.
Does anyone here uses the ifi idefender 3.0 in their qutest x macbook pro usb setup? Do you need the “clean usb power” input on the idefender for the handshake? Apparently last week ive tried switching from optical connection (lifatec glass) to just an atlas usb cable and surprisingly the sound seems more dynamic, more alive (which wasnt the case i started using usb connection and found optical to be better in the beginning) So im thinking of cutting the usb power off the macbook pro using the idefender. Hope to hear inputs on this thanks.
I used to find usb input for mojo, slightly more dynamic and alive than optical input. Unfortunately they tend to be synonyms for added RFI and noise.
Thank you for answering @Rob Watts Rob. Much appreciated. The other day i have tried installing the ifi idefender 3.0 (used to cut the vbus from source) but it needs a clean power connected through its female usb micro slot on the idefender. I didnt connect any power but it still worked. That is why im asking this question. Cause without the power the qutest still recognized the macbook pro. Can you please clarify @iFi audio ? Thank you.Yes it needs the VBUS from the source to power the USB decoder chip, which is placed at the source side of the galvanic isolator - this means that the decoding noise cannot affect the DAC.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Clarify what exactly, if we may ask?
