Hifi Boy
- Dec 10, 2016
I've read it several times before actually and its once of the nicest reviews out there in my opinion.
Could you give a quick technical explanation as to why. E.g., due to "the difference of leakage of the appropriate antialiasing filters into the audible band", or whatever the real reason is.their will always be SQ differences based on AB tests
What you would expect is that the bandwidth limiting filter needs to be quite a bit simpler than the interpolation filter. This due to that the high frequency content is much lower level hence the aliasing when bandwidth limiting is smaller for a given filter kernel. What I think will be interesting is how much better performance you get using a bandwidth limiting filter close to a SINC function rather than, for example, an IIR filter.I am less worried about the decimation aliasing issue - that I can and already have eliminated that. I am more concerned about the interpolation issue, which in principle can be fixed by getting closer to an ideal sinc function; I suspect the bandwidth limitation needed for sampling theory will prove to be a red herring; I guess I am most worried about the bit reduction to 16 bits for CD upsetting depth perception.
Rob has suggested that his (still being designed) power pulse array amplifier(s) will be a worthwhile improvement over DAVE for difficult to drive headphones. 20W per channel into 8 ohms is about the minimum power level (the amps are primarily for speakers), so it's a question of patience...Now and again I get 'motivated' to revisit old sites/threads just to 'catch-up'
this review interested me for several reasons:-
https://audiobacon.net/2018/02/15/w...headphone-amplifier-15000-musical-indulgence/
I couldn't believe there were no comments,so I posted one!(unusual for me!)
I then went back to the 15th Feb(date of review) on this thread to note if there had been any response to this review!
Interestingly not! However,there has been several comments since that date which make this review relevant.
One question concerning the use of the Abyss Phi(with the DAVE) and another questioning the need for an external Amp instead of the DAVE!
So, perhaps the review may provoke some response here which I would be interested to note??
Difficult to drive headphones? So, this amplifier will indeed be both a speaker and a proper headphone amp as well?Rob has suggested that his (still being designed) power pulse array amplifier(s) will be a worthwhile improvement over DAVE for difficult to drive headphones. 20W per channel into 8 ohms is about the minimum power level (the amps are primarily for speakers), so it's a question of patience...
Now playing: The Durutti Column - The First Aspect of the Same Thing
Yup, makes sense, I'm still hoping its gonna be a headphone amp as well.It may or may not be, but you can drive headphones off the speaker taps of an amplifier, usually with an adapter of some sorts (like HiFiMan made for the HE-6) or directly from solid state amps, if you have very insensitive headphones and are careful with the volume.
I could do optical out of my oppo-105 with files from an Lacie external drive.The AES input on DAVE doesn't have any galvanic isolation. So if your AES cable is properly constructed with the shield connected to pin 1 at only one end, and you plug that end into your Alpha USB, then you should get good sound quality with DAVE, even though the AES input on DAVE is generally regarded as the worst input. Common mode RF noise cannot get into DAVE with this configuration, since the differential (balanced) AES signalling cancels that noise.
If you have an optical output on a streamer or computer, you should try connecting that to DAVE using the optical cable that came with DAVE. Make sure it's the only connection to DAVE when you're listening, to ensure perfect galvanic isolation. If you can do this, then this is the "benchmark" sound quality that you can use to compare with the AES feed from the Alpha USB or with the USB input on DAVE itself.
DAVE's USB input has good galvanic isolation, but it's not perfect. In theory the Alpha USB with a correctly configured AES cable will be better. Unfortunately it seems AES cables are often constructed with pin 1 connected to the shield at both ends of the cable, which then causes RF problems in the DAC (whether it's DAVE or any other DAC).
Now playing: Suzanne Vega - Tom's Diner
Sweet, sounds like you have everything you need to work out what's best.I could do optical out of my oppo-105 with files from an Lacie external drive.
Just got my hands on a DAVE and it's the clear winner vs. Yggy for classical - I'm listening to a HIP recording of Haydn, Festetics Quartet's Complete String Quartets, which never sounded quite right on the Yggy, but with DAVE it's perfect. I could listen to this all night. Pop/Rock/Indie/Rap though, think I'm liking the Yggy more. Father John Misty through the DAVE seems a little boring, something I never feel with the Yggy. Same listening to Charles Bradley. And I can only keep one.. this is going to be a really tough decision. Wonder if my ears will get used to DAVE for pop.
