ecwl
I agree with Jawed on the speaker positioning. Sometimes, this "vertically wide" soundstage which I suspect means too much depth? Is actually the instruments sounding thin because the speakers are spaced too far apart or the speakers are not toed-in enough. If the bass sounds pretty good already, instead of moving your speakers, you may just want to toe them in slightly more. A few degrees maybe enough.
The bigger issue I think it's just one of personal preference. I think the sound you described you liked from tube amplifiers + Metrum Pavane is partly coming from 2nd and 3rd harmonic distortions. It can create an artificially warmer sound where the instruments artificially feel more 3-dimensional but you lose details in the sound. You like what you like so pairing tube amplifiers with DAVE instead of Vitus with DAVE can probably solve the problem. Moreover, I have seen and heard systems with tubes and R2R DACs where because the sound is so much artificially warmer that they purposefully set the speakers further apart to thin out the effects.
