Malcyg
- May 5, 2017
Interesting observations. Its been a while since I read this entire thread from the beginning but I was under the impression that the DAVE is relatively source insensitive when using its USB input. I use the Melco N1A but have been exploring alternatives, mainly to try Acourate and, possibly, ROON.
In view of ecwl's experience of ROON vs JRiver on the Blu 2 thread (see quote below), I am wondering if the improvements you noticed could have been due to ROON on the Innuos being better than Twonky (or MinimServer) running on the Melco? Or even the fact that the Innous USB outputs directly to the DAVE whereas the Netgear router is in the signal pathway for the Melco USB output?
I could have possibly misunderstood your system configuration when comparing the Melco USB output vs the Innuous SE USB output. No criticism intended here; I am just trying to understand how the various variables matter. Thanks.
I think you understand it almost right. I previously had a PC as Roon core which dragged files from Melco, through the router and output them again, via router, to a mRendu. For Melco output by USB direct to DAC without going through the router does not involve Roon at all as Melco cannot interact with Roon in anyway other than just being a designated file server, so not comparing exactly like with like. I don't believe that the degree of difference can be down to Roon vs Twonky to be honest but the Zenith SE is not a fair comparison with a Melco N1-A and a higher model Melco like the N1-Z would be a fairer test.
