Wow, I have to say these three new products are very exciting. I would go so far as to say that I expect Hugo 2 will probably sound surprisingly close to DAVE (more so than Hugo TT).
I've only just realised that Blu Mk 2 is doing something very special: it completely replaces the first stage upsampling in DAVE. DAVE's first stage upsampler takes 1xFS to 16xFS audio and creates 16xFS as its output.
DAVE can't upsample a digital stream that is already at 16xFS (705.6KHz). So the 1st Stage WTA Interpolation Filter is a pass-through stage:
DAVE simply does the following stages ("Cross Feed...", "WTA 2nd Stage Interpolation filter...", "Linear Interpolation filter..." etc.).
Now I understand the talk about the new FPGA in Blu Mk 2 being "extremely noisy", using lots of power and being disruptive to the "quiet" environment inside DAVE. Keeping the two boxes separate was always a key concept from the start of the CD transport + DAC configuration that arose back in the 1980s: each box being optimised for the specific job and the final audio signal remaining unpolluted by the transport.
I dare say in a few years' time the FPGA in Blu Mk 2 will be superseded by something at lower power and cost (as we saw with the FPGA in Mojo). At that time DAVE 2 can do everything in one box for those who just want a replacement for DAVE.
The idea that later this year there could be an upsampler that uses the Blu Mk 2 FPGA but has no transport while supporting USB, as an upgrade for DAVE, is also pretty exciting. I wonder if that box will connect to DAVE through USB instead of BNC?...
So, now the big question, one which I have no doubt Rob is expecting to be asked:
is one million taps enough? I can't help thinking that the apparently large jump in performance beyond DAVE's 164,000 taps is indicative that there's much more in them thar 44.1KHz at 16-bit bits. Perfect sound forever? Well it simply took almost forever to arrive...
Perhaps when the dedicated streaming upsampler is released there'll be an option to use two of them: one for the left channel and the other for the right channel. 2 million taps...
Now playing: Mark Lanegan - Borracho
