Matt Bartlett
Member of the Trade: Chord Electronics
Nope. Something is definitely wrong. On a normal device I would factory reset it by now, but there's just no way to here. The Config button menu is broken. I go to switch modes and it shuts Poly off.
If this has happened to anyone else (it looks like it has to @AndrewC88, via my quote up above), I'd appreciate some feedback. I sent an email to Chord. We'll see what they come up with, but really feeling like returning it at this point. Huge disappointment.
Hi @joshnor713 and @AndrewC88
Apologies I wasn't available yesterday evening to assist you both with this.
It does sound like the update to firmware version 1.0.41 which then allows you to jump to the latest V2.0 firmware has failed and left your Polys with corrupted firmware so they are now running in fail safe mode. This is frustrating and I can only apologise but it can be fixed by a manual update process that I can force through from our update server. What I need you both to do is press the config button so Poly goes into access point mode ( The P status light will flash Blue and green ). Then using your phone or computer scan for the WiFi signal coming from Poly and you should see Poly then a long number displayed (Poly-xxxxxxx). Can you PM me this then I will give you further instructions. I may not be able to do anything until Tuesday now as it is the spring holiday in the UK but I will try.
Matt
