mashuto
- Sep 23, 2016
As I’ve said beofore in this thread (only 635 posts go), “About SQ, there is not much to say except that Poly allows Mojo to sound its absolute best. This is down to these 3 things, as far as I can gather:
The Poly has a very fast, and - I assume - electrically quiet processor and circuitry custom designed for audio.
The elimination of power supply noise (when running only on battery).
The elimination of any RFI from the USB cable, all add up to better sound.
So, a few small things that really do add up.”
You may already be lucky enough to have a completely optimized system with Mojo and so won’t see any improvement from Poly. But many people have small RFI or other issues that Poly/Mojo fixes. So, Poly allows Mojo to sound its best.
I may be alone on this, but I have posted many many times in this thread that the RFI noise I get using the poly is actually worse than I get with the mojo. Its not the exact same noise, but with my IEMs its extremely extremely noticeable when using the poly, and after posting here many times and debating whether to send my poly in for service to get it checked out (wouldnt be the first time) I get the idea that its just the way it is.
The RFI noise on the mojo was always the cell phone RFI stuff that would be transmitted over usb from my phone to the mojo. Similar to if you hold your phone up to an old unshielded speaker. With the poly, the wifi radio generates its own interference that I can hear on my headphones. And it happens a lot. Any time I perform any action that uses the wifi (even just scrolling through the dlna library on an app on my phone causes it). While its not really audible during louder portions, its extremely noticeable for me during quieter portions of songs or when nothing is playing.
And I dont know if it was ever a direct promise, but it has been said in here that using the poly was supposed to eliminate the RFI interference, but my experience has been the exact opposite. To the point that I almost never use my poly because its so annoying that a piece of equipment that cost over $1100 combined would have such annoying noise almost all the time.
For reference, my number 1 IEMs I use this with are campfire atlas. I have tested with other campfire iems, and some of my other iems too. Some work better than others. I also tried with a sennheiser HD6XX which had no noise. I tried moving my IEMs from one mojo jack to the other, which helped in certain circumstances (like at home vs work), though not at all in others. Of course I was told by chord in this thread that it shouldnt have made any difference. Then I was told that it might have been the cable picking up the noise directly. And yes if I move the cable directly in front of the radio window its worse. But there is no position I can move the cable to completely eliminate it. Same IEMs never pick up any interference from any other device, not on my phone, not using a bluetooth dac (radsone es100) or anything else. Felt a bit like that whole apple situation "Youre holding it wrong".
I stick around because the sound quality (when theres no interference) is just amazing, and the experience when its working right is pretty great. But... I dunno.
