I've tried to figure this out via several websites but not luck so far or I don't understand.
From what I've found airplay still gets you CD quality and it does work without being online (wifi or 4g connection)?
Can android use a similar procedure where you can use the Mojo/Poly to play music you select on your smartphone (locally stored / downloaded onto the smartphone, ie tidal offline or flac files) without using bluetooth (converting to lossy) or using 4G connection mobile data as hotspot (I personally don't have unlimited data)...
TL;DR: Can you stream offline tidal music or locally stored FLAC files from your Android smartphone to the Mojo / Poly without the use of a cable or bluetooth and still have lossless music coming out of your headphones that are plugged into the Mojo?
