Amberlamps
Formerly known as Phuca
- Jan 22, 2017
Thanks!
If I understand you correctly, Glider does currently provide this feature. If you navigate to the Glider settings and disable the 'Consolidate Outputs' option, then you should see three outputs for your Poly in the output selector: one for UPnP, another for MPD, and another for AirPlay (under '... More Devices').
This is actually an issue with the Poly firmware changing the unique identifier of the media server over time, but we put in a workaround fix for this back in March of this year. If you're still seeing duplicate entries after a delete and re-install of Glider from the App Store then please let me know.
The problem here is that the Poly's UPnP media server does not currently support AIFF files, but the MPD server does (though without any metadata).
It probably does Joe, it’s more likely a 1D10T error on my part. Glider gets updated frequently, and at times I don’t notice new changes for ages afterwards. Usually I just start glider, find a song and push play. I only go into the settings when I have a problem, then I see new stuff that was added months ago. like that consolidated outputs addition, which I only saw for the first time on saturday night,
