What's the simplest way to create the playlists necessary for Poly to read and control via Bluetooth ?
Found the wiki and will dive in there http://www.map-pin.com/wiki/doku.php?id=chordpoly EDIT: found most useful information on the wiki an got what I was looking for in no time, thank you @JeremyLaurenson
It's a great little all round device, the only issue I had was keeping it in the pocket of my laptop backpack kept switching it on. I have it with me at all times. I did also get a reduced offer making it an ever better bargain.
Really same old news, it's close, but I also wanted to know about the firmware update to fix the poly duplicates, that I was told was done, but not released 2 weeks ago; and would be in days. So to sum up, we've been told days, not weeks. PS I got interrupted before I could finish. While I may be surprised, I did read somewhere, that Chord has stated that all the connectivity issues, are complex, and likely will not be all be fixed at the same time. So I resigned myself to the fact, that it's taking time. I check at least once a day. The good news, is John Darko, wrote an updated review of his use of the PolyMojo, with the Beta GoFigure app, and he felt it was really positive, minus a few known issues. He did do a little comparison to products Chord Poly Mojo competes with, and he stated, nothing matches the poly, with the variety of ways to connect; but with variety comes more complexity.
How to setup MALP? Can anyone help me? I do not know how to setup the profile page too. 1) what profile name should I put? 2) What hostname or IP should I put? 3) is port 6600? 4) Enable streaming? 5) Enable prefer http cover files? I am using Bubble apps with hotspot. The issue for this apps is the playlist only allow around 16 songs. Now using mojo with dap instead of poly.
1) what profile name should I put? Name the profile(s) whatever you want. I have 2 - named "Poly Home" and "Poly Mobile" 2) What hostname or IP should I put? Put in Poly's IP address. When at home my router assigns Poly a fixed IP. Out and about my phone (using its own hotspot) assigns it a different (fixed) one. Then its a simple matter to switch between the 2 profiles depending on usage. 3) is port 6600? Port 6600 is the standard comms port that MALP uses to communicate to Poly. Leave it as is. No password. 4) Enable streaming? Nope 5) Enable prefer http cover files? Nope Save the profile - MALP should now connect and display Music Library of SD files. Unfortunately right now there is a bug in Poly so it won't display MP3 or DSD files in the library (FLACs show up fine). They will still play ok but you'll have to navigate to them using File browsing in MALP. One immediate benefit you might notice - true gapless playback of SD files! It's the only way I know right now.
I added my data points to the survey. One suggestion to Chord, the release of the gofigure app should be closely followed with a digital manual with embedded videos that incorporates all the knowledge gathered from this forum, the wiki, and other sources. Even with the app, stuff happens and we will all still need the paper clip hole at some point. Clear understanding of how the system works in various environments and how the baseline environments should be configured will be helpful. There will always be someone out there with the most convoluted environment imaginable, so we should not expect every case to be covered, but from the basics the outliers can be worked out. Those of us wth odd environments probably have a better understanding of the tech functions anyway. Those of us with dial up modems connected to a Lisa will always be challenged though.
https://chordelectronics.co.uk/wp-content/uploads/2017/01/Gofigure-Manual-English.pdf Interesting. The GoFigure manual is up. @Matt Bartlett @Mojo ideas are we there now? Not up on App Store yet.
Just go through the manual of Gofigure, and I have some questions on the Quickplay function. @Mojo ideas Is it using bluetooth to control the Poly for music playback? Or does it require WIFI connection? Also, what kind of files does it support? Both FLAC and DSD? Thanks.
