This thread is as of now at 7765 posts and I find it hard to get to specific info I look for.
I got a replacement poly and it works nicely with roon, however, whenever I fully charge the m/p, poly stays on after I disconnect from the charger. I use the pin to enter config mode, green/blue flashing, waiting a bit, turning on and off again results in both, p and m status led off
now: what are the steps to get into playback from sd card using glider at home at my usual network I use it in roon mode, and what if I want poly to be fully portable, playback from sd card? what is exactly the hotspot mode? and why dont I ever see the network name as TomisPoly I enter in setup, and which is saved and shown consistently, but only something like the initial poly-534343434 SSID which gets me to the setuppage poly.audio?
I like the usage of roon, but something else, like mobile tidal playback, glider usage, sd card playback, and switching between modes, is a bit of guessing game for me, any help or sum up of the different types of usage and what to enter in the setup, would be highly appreciated.
thank you!
cheers,
tomi
