I decided to give Hugo 2 a first listen after all the glowing reviews from both the media and the user base alike. I also brought Mojopoly along for comparison purposes.
My hidden intention was to buy myself a unit, in spite of the price, which along with the case is double that of Mojo and Poly.
My first thought was that I quite like the design, which it seems has proven to be quite polarising. What I liked less was how light H2 felt- it almost felt “cheap” next to Mojo as the two weigh almost the same.
While I could hear a difference listening to tracks on Tidal HiFi already (I’m sure it will grow along with a file’s higher quality), I didn’t feel blown away by it. Yes, the filters were great and there is undoubtedly a LOT of power in H2;
HOWEVER- in my opinion Mojo wasn’t too far behind. Had I bought the H2, it would have ended up seeing very little use like Mojo did before Poly.
I realised that the sort of versatility gained through Poly is what is allowing me to enjoy using Mojo. I still plan to purchase a H2 as and when 2Go becomes available but I am more than happy owning M+P;
I had a similar experience as yourself
Since February, I have sunk roughly £3000 into buying new Chord products, A second mojo and another Poly and case and a Hugo 2 and hugo case.
I love the hardware that Chord makes, like you I still prefer using my mojo/poly more than Hugo 2, mojo is so good that I use it much more than my Hugo2.
I think I use it more because its so portable, unlike hugo2 which is attached to an optical cable, so its static and cant really be moved unless I disconnect the optical cable, hence why I can’t wait for 2go to be released.
My library is a mix of flac/alac/dff/dsf/dxd and a handful of wav and the same again with ape and the ubiquitous mp3 from the olden days which just doesnt want to die.
With the above filetypes, their has been a few times where I have said to myself, What was that noise ? I dont recall this song sounding so bad, or, hearing a noise/some instrument in the background that I couldnt hear before hugo 2.
I did some tests and it turns out that Hugo 2 is so good at doing its job, its showing just how bad some of my files really are.
The clarity of hugo 2 is so good that it quickly lets you know if its being fed manure.
I know mojo is a small Hugo 2 with less taps and running at half speed of the hugo2 if I recall correctly, but even so, I love the sound of mojo and in my opinion Hugo 2 takes some getting used too, I think because it has a crystal clear and sharp sound whilst Mojo has a warmer sound.
They are both great and I cant wait for 2go to come out as I will snap that up in a heartbeat, regardless of the mess that was poly’s release.
Edit,
I am waiting for the new upgraded intona to come out ( they are in the process of updating them, hopefully to usb3 ) so I can add usb galvanic isolation to hugo2.
