Well, this is fascinating. Even so, that I'll post here for the first time.
To make this clear, I'm own Chord products.
I think both sides here are not fair. Yes the Poly is expensive but then, it's a Chord product.
To the members posting here. I belief the bashing and sarcasm is not fair.
To Mr. John Franks which I'm highly respect, do you think it is fair, even I'm understand you have to sell your product, to
make the below Quote to someone which apparently don't understand much about BT
thought experiment ...Actually that's it interesting as an idea but with a small plastic end cover on poly you might do this without Poly being connected to mojo so you'd have a ton of music for your BT phone's with a small neat ( end covered) Poly in a pocket and you wouldn't need to have your music cluttering up your phone. Can it be done I'm sure it can. Would it sound as good as Poly and Mojo together? Unfortunately not but sometimes and for some people that may not matter!
to buy a Poly for the only argument not to have his music cluttering his phone? More or less buy a Poly so you don't waist
your phone memory? In other words the Poly is then nothing else as a overpriced external SD card? Because that is what
the Poly in this scenario will be and nothing else.
And since the Poly needs a phone with BT to operate anyway makes this argument even less appreciative.
Just connect your BT headset directly with your phone. Problem solved.
