Poly and Samsung help!
IF the p.status is blinking that is good. The Poly is in default mode.
It will blink until it found à well configured ( for it) connection by wifi or by hotspot.
but it will blink if connected with wifi, not well configured for it, until you will delete it in its memory.
Have try to connect with the hotspot of your S8?
1. Actived it.
On my S3 the default Wifi name is AndroidAP passname: cmzz9234
You will see yours when you will try to use the hotspot of your S8.
ON MY S3
I go on the menu connexions
I sélect more network
I sélect Point d'Acces et modem
Share the data connection of your S3 via usb,wifi or bluetooth
I Turn on the accès point.
I receve the message"The activation of the pointwill disconnect the wifi." push OK
I receve the message: Point d'acces wifi AndroidAP actif
When you will have done that, we go further.
2. CONFIGURE A CONNECTION IN THE POLY WITH Your Hotspot PARAMETERS.
Reboot the Poly and the Poly status will not blinking and will stay blue When your hotspot is actif.
IF YOU have another wifi connection, than the hotspot, configured in your Poly then Poly connect to it so you have to kill it.
In my home, I have 3 wifi and Poly chooses the ones it wants.
So to Be sure that Poly connects with the hotspot i turn off my 3 wifi or i go in the car or in the garden.
The first i had onfigured my 3 wifi in the Poly. It was the wrong way.
Poly stay connected with one bad configured.
