Finally I bought the Poly for my Mojo 2, i use it mainly outside the home so I'm mainly interested in the hotspot function of the Poly to which I can connect my smartphone using MPD client, the problem is that it doesn't always work correctly, while i have no problem in wifi mode connected to my home modem, MPD client doesn't always connect to Poly's hotspot. The right configuration should be: Hostname/IP adress 192.168.1.1 port 6600, when i can connect it's fine but if I decide to turn off the Mojo2Poly and turn it back on later during the day, it doesn't reconnect correctly.
I think it depends on the Poly hotspot because I have tried different MPD Clients
Anyone using Poly in Hotspot mode with an MPD client know the solution to this problem?
