Hi,
I have a chord mojo poly and have latest gofigure firmware but the gofigure has hard time finding the chord poly but worse yet while it finds my home wifi network it does not any longer connect to it. My phone has no problem connecting to my wifi network so why does gofigure see it but won't connect?
The chord mojo light has three lights on when booted up but then goes to just the two volume lights on...since.cannot find network? If switch to Hotspot the power button turns on..
Any advice.....has worked in past so latest snag frustrating
Mojo will only display in the volume LEDs until some music is received/ processed, and then the power button LED will light to show the sample rate of the music file being processed, eg red = 44.1khz.
Note that the Poly operates in the 2.4Ghz Wi-fi band only, so it’s important that your Wi-fi router has a 2.4Ghz carrier available. If you have made any other changes to your Wi-fi router - password etc - those also need to be done in the Poly too. Perhaps you should setup the Poly Wi-fi over again? Also, when you get the Poly connected perhaps check that you have the latest firmware in the Poly, as well as the latest version of Gofigure on your phone/tablet.
