halomusic
- Apr 1, 2014
it is well for me
is there any detachable cable headphone under $50 ?
Like Somic or Takstar, that are called good headphones.
Somic efi-82mt is very good for its price $40 as i read. it has an immovable cable, right ?
Monoprice 8323 has a detachable cable. Superlux 668b on some some other superluxes also have detachable cables. Efi82mt cable does not come off.
Thanks for the info.
i ve read several reviews about Monoprice and i think it is not so good. for $20, its ok.
but im looking for about $40-50. i think Somics are best choice for this price. over $50 i found Takstar hd6000 for $67, best for its price range. as i read.
Now i think about that; is it worth to pay twice for Takstars instead Somic ? cuz i will not use professional equipments, just onboard sound card of Asrock Z77 Extreme 6 (- 7.1 CH HD Audio with Content Protection (Realtek ALC898 Audio Codec) mobo.![]()
I don't know anything about the hd6000 but I find the Pro80's to be quiet a bit better all over than the Efi82MT.
and hd6000 is a bit better than pro 80.
To my taste monoprices have too smooth highs but other than that I like it better than efi82mt. For me efi82mt was a major disappointment after all the hype. It is better than average headphones in its pricerange but compared to best of it's league it is nothing special. If you could get somic mm185 for cheap that would propably be a better one. I have not heard it though but atleast it has nice pads. With efi getting new pads is mandatory, the stock ones are completely useless.
I agree on the efi82mt, I was also disappointed with them. They're not bad but I expected more.
