Regarding NiceHCK F3 with beats dual flange tips bass is awesome and highs are more controlled. I have over 150 hours on them now and they sound great like this.
Chinese / Asian Brand IEM Info Thread
- Thread starter Brooko
I am loving the CCA CA4 our of the AP80, sounds great for my lunchtime workout at work...
FastAndClean
Previously known as presata
clean them a little bit, we cant see your faceRegarding NiceHCK F3 with beats dual flange tips bass is awesome and highs are more controlled. I have over 150 hours on them now and they sound great like this.
hifi80sman
Any good recommendations for an MMCX IEM that can be worn wire-down vs. around ear method? I just picked up the FiiO F5 (liking these quite a bit) and the Tin T3, but looking to see if some of the commonly worn around ear also work wire-down.
Nvm, when reading you're post again I don't understand what you're asking.
Are you looking for something made to be worn over the ears that can also be worn straight down or IEM's with mmcx that can be worn straight down??
FastAndClean
PANDAAAAA , i put triple flange tips and the sound is FIRE, thank youRegarding NiceHCK F3 with beats dual flange tips bass is awesome and highs are more controlled. I have over 150 hours on them now and they sound great like this.
Edit - damn Panda, that schiit uncomfortable, i will look for other tips
FastAndClean
after 150 hours of constant play of different colors of noise they started to give up, "burn in is a myth" YEAH RIGHTgood luck these beasts need to be tamed
hifi80sman
That's exactly what I'm looking for, just like the Tin T3 and FiiO F5 can be worn. I cannot wear the wire around the ear method.IEM's with mmcx that can be worn straight down
Ok, than I stand by my original suggestion: ****
Dobrescu George
Reviewer: AudiophileHeaven
Actually he can consider t2
I actually liked both T2 and T2Pro
If you have some extra pairs and don't mind to "mod" one you can cut off the smallest flange of your 3-flange using a sharp/utility knife then you'll get a nice 2-flange. I was used to doing it on my Ety's 3-flange tips and damn it was so comfortable.
FastAndClean
i have only one pair but it turns out that the F3 sound good with other tips also, i will spare them, thanks anyway @MakahlIf you have some extra pairs and don't mind to "mod" one you can cut off the smallest flange of your 3-flange using a sharp/utility knife then you'll get a nice 2-flange. I was used to doing it on my Ety's 3-flange tips and damn it was so comfortable.
Slater
This is actually the only way I can use Xmas trees. Otherwise, the top-most flange irritates my ears. It makes them feel like bugs are crawling around inside my canals!
Otto Motor
Now you need a second, fresh pair for comparison.after 150 hours of constant play of different colors of noise they started to give up, "burn in is a myth" YEAH RIGHT
Total: 13 (members: 0, guests: 13)
