Slater
After Slater's review of the QKZ VK1, I canceled my order and got a UiiSii CM5 instead (the $12 black ones on Amazon which I understand are the large ones). It arrived this morning and my impressions are similar to what's been described before: it does everything pretty well, there is nothing offensive about its sound (e.g. no overpowering bass, no sharp highs, nothing that requires EQ out of the box); an overall solid IEM. It has a graphene driver so I expect that with further listening the sound should evolve a bit. Even though they are very comfortable, I had fit issues as others have mentioned. For some reason I couldn't achieve a perfect seal with the right earpiece using the included tips leading to inadequate bass. I ended up putting on KZ Whirlwind tips which seem to be working well. I'm also a fan of the cable even though it's not replaceable and has a mic*. It's light and transmits very little microphonics. Because of those features, the CM5 + bluetooth receiver will become my go-to work out IEMs. Very solid pick for $12.
Now, even though I have plenty to enjoy, I'm still intrigued by the TRN V20. Does it do anything better than others at its price point? I'm pretty sure it would be redundant given what's already in my collection but I am curious nevertheless. I think I'm going to take a break from ordering more IEMs. Until the next hype train, of course .
*As an aside, I'm not sure why some people are anti-mic here; does it really have a negative effect on sound quality? I still find it useful.
Edit: I should also mention that the CM5 packaging is wonderful. The instruction manual was actually helpful for a change and the case was a nice added bonus. These are great gifts!
I think you made the right choice.
While the VK1 is good, the CM5 is better (and cheaper). I think it looks stupid (like a bunch of bananas in your ear as someone said), but how it sounds is the most important thing
Smart move on the Starlines as well. They are the key to unlocking the CM5's potential!
