CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
May 7, 2018 at 2:30 AM Post #10,321 of 31,833
Will consider buying the nicehck dt300s within the next couple of weeks. Need to see what other sub-$150 Shure-shaped models compete, but these are looking good.
Does anyone know where I can buy these!?
May 7, 2018 at 3:23 AM Post #10,323 of 31,833
Can someone test this song for me on the ZS10 or Tin Audio T2? It sounds really sibilant to me. Not sure if it's my gear or the song itself or just my ears.
Not all tracks are recorded equally. I listened to the samples you originally posted and then I listened to the following sample:
I listened to both samples on a relatively warm but detailed IEM (KZ ZSR) and both came through exceptionally clear but I did have to lower the volume 2db because the upper-midrange was pushing the envelope with very mild discomfort. Tolerating slight discomfort for extended listening sessions is a surefire way to damage your hearing if you consistently say to yourself "it seems a bit annoying but I guess it's ok". It'always best to err on the side of caution and save your hearing.
The material point is that the track in question pushes the envelope but when I switched to another set of tracks I could comfortably resume my previous listening volume (+2db) by increasing the volume.
Every frequency from top to bottom was clear, vivid and detailed without issue on the following tracks:
May 7, 2018 at 3:58 AM Post #10,325 of 31,833
May 7, 2018 at 5:51 AM Post #10,328 of 31,833
if i dont have the t2, should i go for the t1 or t2 now?
T1 if you like a little extra bass and warmth in your music. T2 is very neutral, more resolving and has less than average amount of bass. So basically T1 = more fun and inviting. T2 = more analytical and detailed.
Here's a quick measurement of both. The T1 is blue/red, T2 is grey.
May 7, 2018 at 6:57 AM Post #10,330 of 31,833
May 7, 2018 at 7:42 AM Post #10,331 of 31,833
May 7, 2018 at 8:41 AM Post #10,332 of 31,833
The **** UES aesthetically reminds me of those cheap glitter rubber balls that are used as cheap concession prizes...
May 7, 2018 at 9:21 AM Post #10,333 of 31,833
**** UEs are great by the way..
But that marketing with the guy wearing **** with that cable they don't even ship it with make me feel bad..
That transparent angled mmcx looks slick..
I ant to ask about the stage, image and separation about these.
I was able to listen to friend’s UEs.
But I was not able to listen to my tracks..only his classical songs.
And anybody got the EN900
May 7, 2018 at 9:39 AM Post #10,334 of 31,833
Long time waiting and the connector doesn't work with the pin of the iem.
Not all packages from china comes with happiness.
The ez ask is screaming: "DON'T GIVE UP ON ME".
- its too late my dear, time to move on. Sorry
May 7, 2018 at 9:45 AM Post #10,335 of 31,833
u mean this guy?
m0UonocWEV_wAQyh-Y82XKx03-rx55l0B3q5edwv0bl-Xr7DGB2bdjrLBtrLo4riYX7rWTQPNojr3dDaDg=w1000-no-tmp.jpg
