Easy to wear, fit is good, isolation is really great.
Bass response is fast, mids are good. The trebles are pretty mild for my liking (coming from TA T2 and 4in1). Pretty V shaped but more emphasis on the lower ends imo
But to get it with the 6 pairs whirlwind tips that is
@Slater approved, and its only like 10bucks (minus off 5 bucks for the tips, ITS ONLY LIKE 5 BUCKS!!!???!?!?!?! PS: Without MMCX cables though), i must say the $ to performance value is
INSANE. They are better than my WKZ Pro W1 for sure.
From my memory, it is better than the KZ ATE and ATR fit wise, and probably soundwise (no good fit for me with those, and i also didnt had an arsenal of tips to do tip rolling then. I can only say if i had some KZ starlines back then, they will probably sound good)
It beats the T2 in bass and isolation, sub-bass, but its not the nicest bass i have heard.
TLDR: Silly at the price point if u already have a MMCX cable, need a good workout or commute earphone. Isolation after changing tips is sweeeeeet~
Tried to this performance and not piercing like the 4in1 > Tinaudio T2 > Tennmak Piano xD i dont understand the language but this performance has so much feel
