dhruvmeena96
You can get zero audio carbo I....they sound nearly same to tenors, just more linear bass, strong build and more isolation
Well, you guys wanna know
The best iem I have listened too..
Blue Ever Blue 2000ex.
Well, this is something I call sound
Seriously...? I've held off reviewing them for way too long because they're very, very underwhelming. 1200EX is miles ahead.
Dunno, but my buddy got 1200ex and 2000ex HDSS....and I tried both.
1200ex sounded like mid centric.
2000ex sounded right(but this was when my ears pained a lot due to cheapo fi fake 1$ bud I used to use for fun and modding.... I had u18t at that time by the way
And it had enjoyable soundstage
Well I edited it....I wanted to write soundstageAgree about the sound stage but the mid-range was extremely forward and shouty. Sub-bass is lacking as well. Treble has a very tinny, cheap quality to it. I like the fit, think they're well built, and the HDSS gimmick seems to work, but the sound quality is seriously lacking at 200 USD.
\Got my Tinaudio T2!!!
HYPED!
The best I have listened under 150usd is
Creative aurvana trio...it smashes the fiio f9 pro, kinera H3, hifiboys osv3.
Well it sounds like mid boosted tralucent 1plus2.. And due to mid boost, it sounds precis in imaging
It sounds compact but accurate, and some songs can scale soundstage to ambience level..
But it is overall a compact sounder.
But after using symbioand linum super BaX balanced, it soundstage increased by hell lot
(Well wear upside down and reversing the cable polarity).
As it is a normal positioning wire down iem
Bro, need some time. OOTB i can only say maybe not to ur liking tho, the bass not very engaging, but sufficient. Quite shiok when listening to Unfinished Sympathy. I wouldnt say its bright since i am coming from **** 4in1. Feels more controlled in a good way, detailed, mids are pleasant. AND THE ISOLATION IS BETTER THAN I EXPECTED xD\
review pls
@oneula
Go get plenue D.....but if you are serious about audio then get a fiio q1mk2 or oppo ha2-se and get onkyo HF player apk or iOS(well I cracked mine on android)...
Well about iem...here comes review
Fiio ex1 mk2: resolution, open and dynamic sounding with great stage and image but lacks isolation(bare open). Treble can be sibilant sometimes but is amazing and can resolve. It scales very good with sources but this is related to DAC's and not Amps...amps can make it clip on high volume.
Fiio F5: improved the mids and Bass on expense of treble but treble is amazing.. It is more of a smooth experience rather than the resolve nature of ex1. F5 gives better depth on expense of little bit height and width(just a small expense) and is great.
Nuforce EDC: somehow normal tuning, compact soundstage but very good image. It is smooth but it engages the listener to listen the instruments more clearly rather than giving it the ambience. Image is its strong point...but it is not closed stage, just a smaller stage to listen...it passes soundscape with bare passing marks but image is where it excels.
Fiio FH1(added by me) : fiio F5 + warmer + depth but expense of a little more height and width....but it is a rounded stage and sounds awesome. Treble is cleaner and between smooth and resolver. It has some decent punch in it and subbass is rumbly and tight.
Don't add KZ ate, atr, ZS3, ED9 and ZST.
For ZST....you can get ES3 which is way better(last 2017 model)
ZSR: upgraded the mids of ES3 and treble was lowered.. But Bass packs a huge punch and warms the sounds. It focus in super Depth due to Phantom Bass nature and creates a cinematic scape. Balanced armature keeps sound clean.
Lker i8: clean mids, good treble, very good scape, no colouring but the peak is glaring at 2k instead of 3k which makes female vocal harsh and sharp and little depth so only wideness and tallness here.
Carbo tenore : lol....perfect tuning here, just weak by body that's why I don't recommend them.. They are perfect Japan tuning you can get. It has soundstage, perfect olive curve response but with a little bass boost and soundscape is awesome..but rolls off quickly in Bass, passes phantom bass marginally.
with 96.6% Positive feedback
http://s.aliexpress.com/iy2IrAvY?fromSns=Hangouts
or
http://s.aliexpress.com/uAVbm226?fromSns=Hangouts
or
http://s.aliexpress.com/632uae2e?fromSns=Hangouts
new stuff on ae,
single Carbon Nanotube diaphragm DD iem.
1. Product Name: SEMKARCH SKC-CNT1 In Ear Earphone
2. Model: SKC-CNT1
3. Drive unit: Single 10mm Carbon Nanotube (CNT) diaphragm high dynamic drive unit
4. Type: In-ear
6. Impedance: 32Ω
7. Earphone sensitivity:108 ±1 dB
8. Frequency range: 10-26000Hz
9. Total harmonic distortion > 0.2%
10.Rated power: 5mW
11.Executive Standard: CTIA International standards, IECQ
12.Earphone plug: 3.5mm
13.Cable Length: 1.2m±5cm
14.Weight: 20g
15.Color:Gray
16.Earphone plug type: Slant Type
17.Whether with mic: No
18.Interface Type: MMCX Connector
19.Whether with cable: Yes
20.Earphone category: HIFI, Monitor
21.Applicable type of music: Classical symphonic concert
PS>>
SEMKARCH is a new brand of LZ (LaoZhong) HIFI Audio company,
Like the LZ A2/A3/A4/A5 the SKC-CNT1 is tuned by the same tuner LaoZhong.
SKC-CNT1 uses 10mm carbon nanotube (CNT) diaphragm high dynamic drive unit, the sound is so amazing, which is a pleasure!
