CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
Aug 2, 2016 at 4:49 AM Post #917 of 31,833
You should try the TY HI-Z.....the sub-bass is epic!
They're actually rose gold cables to match the rose gold housing. But, depending the seller you buy them from, they also come in black! .....I have both rose gold and black cable BK50's.
I'm probably not going to get those, but thanks for the advice. Honestly though the VE Monk sound great I just struggle a lot in getting a proper seal in my ears, but when I do they perform well in the sub-bass/bass area. It's simply the fact that they are ear-buds that make them a bad choice for me, the drivers in them are really good but I can't practically get a seal when using them so I can't fully hear the extent it's range. I'm sticking to in-ear headphones for now, since these are the only ones that I can effectively get a proper seal with.
Edit: You may also ask why I would ever buy ear-buds knowing full well I hate using them... Honestly they got so many good reviews that I figured I would want to hear what all the fuzz was about, and for 5$ it's not exactly breaking the bank.
Aug 2, 2016 at 3:12 PM Post #919 of 31,833
I need some suggestions: what's a good headphone (not IEM) to get under 60$ for outdoor use? I had the Mi headphones, but they were not really suitable for outdoor use and so I gave them to my gf. Looking at the Meizu HD50 right now, are there any better options than that?
Aug 2, 2016 at 6:26 PM Post #920 of 31,833
I got my Xiaomi Hybrids today, these are... underwhelming. I'm not sure if I gt a defective unit, if it's counterfit or if I simply cant get a propper seal. They sound nothing like the reviews point towards, while they actually have a decent sounstage they are completely lacking in bass and sub-bass. Which seems strange to me as thatBeatsguy mentioned them as having a "Solid and impactful" bass in his review.
It's not that I didn't try either. I tried on all the supplied tips as well as comply, Spinfits and Trinity double-flange tips. Nothing truly gets a propper bass, except if I push on them in a very specific direction, then they actually sound decent.
Aug 3, 2016 at 12:06 AM Post #921 of 31,833
Where did u buy from.
Aug 3, 2016 at 2:09 AM Post #922 of 31,833
A bit of an update on the Benjie K9, I managed to get the player to work consistently after a master reset and reformat of the memory card. I really like the sound from the device but the interface is counterintuitive. I'm going to stick it up for sale on eBay.
Part of the reason for flogging it is my latest purchase - an Oppo F1 smartphone - I'm only using it as a music player as I love my iPhone/watch combination but this thing is a revelation. Plenty of volume for IEMs at least and the Dirac sound allows plenty of customisation. It tends to be bassy but I've found the right balance eventually.
Aug 3, 2016 at 3:39 AM Post #923 of 31,833
SoundMagic P21.
http://www.head-fi.org/t/727275/review-soundmagic-p21s-perfect-portable-iphone-android-friendly-portables
Aug 3, 2016 at 5:35 AM Post #924 of 31,833
the ag-rx1 is a complete gem. for the sound, it should be priced >100 usd
Aug 3, 2016 at 7:29 AM Post #925 of 31,833
Here: http://www.aliexpress.com/item/Original-Mi-Xiaomi-Hybrid-Piston-Dual-Driver-Piston4-Earphone-Headphone-Headset-In-Ear-Iron-Noise-Cancel/32663568048.html
I mean I always know there is a risk involved ordering from Aliexpress, but I had hoped these were at least genuine. I see now that at least one other buyer reported the same.
Aug 3, 2016 at 7:37 AM Post #926 of 31,833
You made a mistake, especially since you are buying xiaomi headphones, aliexpress has the highest number of fakes of xiaomi.
Next time, if you are buying xiaomi product, buy from Gearbest or Geekbuying. Infact, you can get these for 16.50 in gearbest now instead of 20 for a fake. try your luck with dispute.
http://www.gearbest.com/earphones/pp_261864.html
Aug 3, 2016 at 7:57 AM Post #927 of 31,833
Yeah that's my thought exactly, Oh well it's not like it was a 100$ pair of headphones either. Still I'm going to try with a dispute.
Aug 3, 2016 at 10:45 AM Post #928 of 31,833
Any link to this Gem?
And what type of soundsignature they have?
Will put it in the list with your little description of you can give one.
Aug 3, 2016 at 10:49 AM Post #929 of 31,833
http://penonaudio.com/Earphones/earbuds/AUGLAMOUR-RX-1
i dont get why its priced at 23.9 usd. its better than ve zen imo.
immersive soundstage, mid centric, addictive subbass!
Aug 3, 2016 at 10:58 AM Post #930 of 31,833
Not to mention the excellent accessories that come with it. I plan to get it one day but no hurry because I rarely use earbuds.
