I'm really struggling so I thought I would ask you guys. I'm on the hunt for compact IEMs. In terms of size, think SE215s or IE300s since I need to wear them under a helmet. I've looked at lots of lists but I'm coming up short. Does anyone have any recommendations for any good ones around $60-80? My ideal sound signature is v-shaped.
A good V-shaped KZ hybrid.
Close relative of KZ ZSX.
If you are OK with the treble, either of C12, ZSX or ZAX will do great for the money.
DQ6 (original) and CRA would be other budget alternatives.
Hello,
Could you please tell me what they are like for passive noise isolation?
Need a new pair for bedtime audiobook listening and the small size and shape look quite comfortable.
Hello,
Of course your ear anatomy will be different from mine, but I found the seal and isolation very good, I obtained a snug fit, as did my wife. You may have to experiment with tip rolling.
I bought a second pair for my wife, the build quality on both seems OK, though we shall have to see about durability. The sound, though, is amazing. I prefer them to the Sony MH755! They are burning in and improving all the time.
I find the Tanchjim OLA excellent, though tonality is very niche the technicalities are incredible for 40$.
Biggest issue for me is the fit, and im not the only one that get this ''iem poping out of my ears'' issue it seem.
Their is my full review: https://www.head-fi.org/showcase/tanchjim-ola.25742/reviews#review-28274
You can find review of FIIO JD3 and JH3 on my site too. JH3 when on sale at 35$ is sure a real bargain, again, technical performance take the front and affect a bit musicality enjoyment, a bit like OLA in that regard.
