theresanarc
Double Flanged tips don't seem to work on KZ ZSN type IEMs. They cause it to stick out too much, any recommendations?
Gettin' my 80's on today with some sweet synthwave and the Blon BL-03:
The BLON is definitely more coloured than the KXXS, so perhaps it's the same with the KPE. I listened to some Erasure with the BLON and those synths and electro notes were fab. Same with the more modern pop i tried. It's got a looser bass, but somehow can hit hard when it needs too. Woofer like even. I had been listening to the VE BIE so took a bit of adjustment with the BLON before i could really hear what it was capable of, very different signatures.
ALSO : As for the short nozzle, try SpinFits, if you see in my pics they definitely help. Just make sure it's a thin inner stem.
Put a black cable and painted the connector too, so they look okish like that imo
I received my NiceHCK DB3 today, just spent 1 minute with them before going back to work, but I'm impressed! can't wait to go back home
Long time I did not enjoyed IEMs sound from this quality. For the price, it's just stunning.
They are currently burn-ing. I will make a full review of it soon (photos already taken)
Holy moly, that's an epic bargain! Nice job
i just made a comparison between **** and BL3
**** have a lot of air at the top, more than BL3, the mids on BL3 are fuller and more natural, bass have similar quantity, probably a tad more on BL3
the timber - not even close, BL3 is in a whole different level, a lot more natural from top to bottom, **** is still very enjoyable for me with instrumental music like Hans Zimmer and various electronic music though
the treble is a bit bright for me on ****, before it was spot on but now is at my limits
What cable do you use with the **** ?Had them both at hand so did the same out of curiosity and must say near enough agree with you entirely. Pretty close in note weight, I'd agree the BL3 is fuller but it's not by much. Bass I agree BL3 has tad more depth, slightly more musical too, **** bit faster decay which can make it a little cold for me, but still full enough. Vocals are very similar, BL3 having bit more emotion with that added colour. For me treble is nicely done on the ****, I personally prefer it compared to the BL3 and that bit more air gives it slightly better separation. Soundstage very very similar. But yes, BL3 the more natural sounding bottom to top and music just flows far better.
May do a comparison later with the BL3 and the Venture Elec BIE which I've only recently had and enjoy.
I used the Nicehck 8-core copper cable, but recently went back to stock cable. It's the newer kind - black and braided. It works fine, but is a bit tangly above the splitter.What cable do you use with the **** ?
I feel basically same with my KPE (modded) vs. BL-03Having jumped between the two i can say they share a lot of similarities in overall sound. The BLON tho has a thicker, more pronounced low end, the KXXS slightly thinner overall due to a tiny bit more air and emphasis in the upper mids. in fact, the BLON is basically a thicker sounding KXXS. The KXXS does though bring out more detail, but not lots more, again due to better separation/air, this is where the BLON struggles a bit for me, little congested at times. KXXS has slightly bigger soundstage, more in width
Wouldn`t call KPE mids bit recessed, rather just "floating" but otherwise agree about KPE vs. BL-03. Bolded parts I agree 100%.Sound of kpe is more balanced and precise. Mids are a bit more recessed tho, which makes the blon sound maybe more emotional on vocals at first. But can get a bit tiring too, say on jazz saxophone, which the kpe never becomes. I have a difficult jazz track which I use to gauge iems and the blon sounds bloated with bad instrument separation, slow decay etc. while the kpe handles it incredibly well. Blon otoh is a bit more fun with the bass of some hip-hop tracks with better sub extension.
Still a very promising company, if they could increase a bit the nozzle length, make a better shell and a good connector that'd be a serious contender for mid-range iems, but as they are, nope.
Ofc it's still a pretty good sound for cheap, too much bass imo but I used to like that.
Seems so.The BLON is definitely more coloured than the KXXS, so perhaps it's the same with the KPE.
Thanks and funny because I use the 2 same cables ... Depending on the DAPI used the Nicehck 8-core copper cable, but recently went back to stock cable. It's the newer kind - black and braided. It works fine, but is a bit tangly above the splitter.
What's the most isolating chifi IEM in this segment, that still sounds good? Like some etymotics etc in terms of stopping outside noise as much as possible?
