Slater
What other metal earbuds you can suggest pls? Which is not very expensive and ideally have Mic also. Also, if we remove the Metal Grille on the back from the earbud, what we will need to cover it then? I also don't want Sound to be leaked but it seems due to open back design, whatever I am listening using MS16, the person next to me or in the same room will also listen that. Is that correct? So if I cover the back completely, will tat affect sound or what?
If you cover the hole completely, it will sound even worse than it does stock. The hole is there to allow the driver air to breathe (it's a vent). The problem is that the metal grille they used has very tiny holes, so it is very restrictive and almost no air can pass. That's why the grille needs to be totally removed.
As far as sound leaking, that tiny vent hole on the back is the least of your worries. Earbuds themselves leak sound everywhere, where the speaker outputs the sound. It's not sealed in your ear like an IEM is (which uses a foam or silicone eartip to create a sealed enclosure in your ear canal).
So yeah, any and every earbud you use will leak sound to a person sitting right next to you. You can control the leakage using the volume of your source device. If you listen at a very low volume they won't really be able to hear your music. But if you listen to any earbud at a realistic volume, a person sitting right next to you will hear your music (or at least be able to hear that you are listening to music, even if they can't make out the specific lyrics).
